E-Body brake line routing, Power to Manual Helpp! #1196706
03/13/12 11:31 PM
03/13/12 11:31 PM
ny
mopar-steve500 Offline OP
ny
Hey everybody, its my first time posting here on moparts, i have a problem, I am restoring a 1971 Dodge challenger and have converted from Power disc brakes, To manual Brakes. when i went to install my new Manual brake cylinder i installed the lines from the proportioning valve but the fittings were opposite sizes and are different sizes, so i crossed them thinking maybe the body shop who painted the car bent up the lines and switched them up. now the front brakes are locked and the rear brakes are free,somethings wrong any help is appreciated, i think the front brakes are controlled by the rear inlet of the master and vice versa
Re: E-Body brake line routing, Power to Manual Helpp! [Re: mopar-steve500] #1196707
03/14/12 01:16 AM
03/14/12 01:16 AM
Memphis
HemiRick Offline
HemiRick  Offline
Memphis
The front brakes a locked because they are plumbed to the port on the MC for the rear brakes whick are drum brakes and need the residual pressure valve. Switch the lines the rear reservior should go to the front brakes. What master are you running? It's strange to have the sizes wrong.
Take care,
Rick
68 Coronet R/T 440 & 68 Charger 528 Hemi,and 5 Challengers! 6 cyl, 318, 360, 383, 451
Re: E-Body brake line routing, Power to Manual Helpp! [Re: HemiRick] #1196708
03/14/12 09:50 AM
03/14/12 09:50 AM
ny
ny
Thanks Alot for the response, its a manual brake cylinder from, Master power brakes and the sizes for the fittings on the master are opposite looking at my power brake cylinder side by side, i have to make new brake lines and make sure i have the right size fittings, do you know of a company that has these pre bent?
