Steering coupler question #1196365
03/13/12 02:27 PM
03/13/12 02:27 PM
Wisconsin
coachoff Offline OP
coachoff  Offline OP
Wisconsin
Hello,
This is my first post, I hope I do it right.
Was a steering coupler ever made with the 'tall body' that will fit a manual steering box?
I have a manual steering coupler that has a 'short body' and a power steering coupler that has a 'tall body'. With the short coupler, it is just a bit too far away from the steering gear. The 'long body' would be perfect, but the hole is too big. Any ideas?
My car is a 67 Belvedere I
67 Belvedere I
69 Road Runner
72 Road Runner
Re: Steering coupler question [Re: coachoff] #1196366
03/13/12 03:34 PM
03/13/12 03:34 PM
Anywhere the British Secret Se...
Moonraker Offline
Moonraker  Offline
Hello and welcome to the board. Your steering column can expand to make up this difference. If you have your column out you should see 2 plastic sheer pins in the column which may or may not be broken already. If they arent broken try and remove them so you can reuse them. Once out you should be able to lengthen the steering column to the right length, there should be a set of holes in the inner shaft that line up with the holes in the outer shaft. Reinsert the old sheer pins or use nylon screws.
Re: Steering coupler question [Re: coachoff] #1196367
03/13/12 03:36 PM
03/13/12 03:36 PM
Moonraker Offline
Moonraker  Offline
here a post going right now that may be of some help as well
https://board.moparts.org/ubbthreads/show...e=0#Post7108249
Re: Steering coupler question [Re: coachoff] #1196368
03/13/12 04:10 PM
03/13/12 04:10 PM
IMGTX Online content
IMGTX  Online Content
Just a little FYI.
Those are not sheer pins but injection molding holes for a plastic material that was used to support and hold the two shafts together. In an accident the shaft can collapse. If you shorten the shaft it may not collapse in an accident and may cause further injury. If you lengthen it it may not stay together. I doubt this very much since I believe there is plenty of overlap but why risk it.
You have two problems when going from power to manual or vice versa. The shaft length and the size of the spline on the coupler.
Here are a couple of options that safely solve both problems
http://www.flamingriver.com/index.php/products/c0008/s0009/FR1505M
On this page go all the way to the bottom and there is a part ST-SCA.
http://www.jimsautoparts.com/steering_parts.htm
there may be other suppliers to provide parts for this situation.
Hopefully someone will chime in.
Re: Steering coupler question [Re: Moonraker] #1196369
03/13/12 05:08 PM
03/13/12 05:08 PM
Wisconsin
coachoff Offline OP
coachoff  Offline OP
Wisconsin
Thanks for the replies. I guess I should have said that steering column is a frankenstein made when I went from a "three on the tree" to a floor shift. I got an upper 'can' setup off of the E-bag and put it on my column. The bearings and everything up top fits, the issue I have is the lower part seems shorter. I marked the steering shaft before I removed it and it is in the same position. I'm about 1/2 inch away from being able to use the small coupler.
My car always had manual steering and I can't find the origional steering coupler. I did have the two couplers to compare and he long coupler should cover the shoes. The problem with the long coupler I have is it has a power steering spline and won't work on the manual box. I guess I'm just wondering if Ma Mopar made a coupler that was tall but with manual box splines?
Re: Steering coupler question [Re: coachoff] #1196370
03/13/12 05:10 PM
03/13/12 05:10 PM
Oklahoma City OK
Cudajon Offline
Cudajon  Offline
Oklahoma City OK
I bought a Firm Feel universal coupler to get rid of the mopar coupler and I couldn't be happier.
