lash caps #1196293
03/13/12 09:59 AM
03/13/12 09:59 AM
NEW HAMPSHIRE AND MAINE
BIGSTROKER Offline OP
ok all you valve train experts here's the question
i have a 440 base 493, victor heads, .600" solid roller and hughes rockers. my scrub centerline is .020 low towards the exhaust ports
if i install a .080 lash cap would it raise the scrub mark or lower it
Re: lash caps [Re: BIGSTROKER] #1196294
03/13/12 11:04 AM
03/13/12 11:04 AM
Mt. Vernon, Ohio
dartman366 Offline
dartman366  Offline
Mt. Vernon, Ohio
depend's on where you are in the radius of the rocker travel,but more than likely would raise it, I would be more concerned where the roller is in mid and full lift
Re: lash caps [Re: dartman366] #1196295
03/13/12 11:42 AM
03/13/12 11:42 AM
i'll let you know as soon as i pound these beauties on there and check it
thanks
Re: lash caps [Re: BIGSTROKER] #1196296
03/13/12 02:12 PM
03/13/12 02:12 PM
nielsville, minn.
Q
quickd100 Offline
quickd100  Offline
Q
nielsville, minn.
They don't pound on, they're a slip fit. Also make SURE they don't seat on the keepers. Dave
Re: lash caps [Re: BIGSTROKER] #1196297
03/13/12 02:24 PM
03/13/12 02:24 PM
thanks
You just found out the main reason to use lash caps, to keep from pounding the valve stems out. Use a file or stone to reduce the beat up top part of the valve stem so the lash caps will slide on and off the valve stems easily
Re: lash caps [Re: Cab_Burge] #1196298
03/13/12 07:11 PM
03/13/12 07:11 PM
nc
E
emarine01 Offline
emarine01  Offline
E
nc
The lash cap will raise it... plus you cant come close to the edge of the cap
