Re: Earlier Dodge Diesel Availability?
[Re: 4speeds4me]
#1195506
03/12/12 03:03 AM
03/12/12 03:03 AM
Posts: 284 Bennett, Colorado
Charger69RT8
Bennett, Colorado
There was a small diesel offered in the 70's but to my memory it wasn't anywhere near a 383. A six cylinder I believe. There was one in the small New Mexico town I lived in in the early 80's. I had a brief conversation with the owner once but never saw under the hood.
2012 Challenger SRT 2012 Charger SXT AWD 69 Charger R/T 78 Chrysler New Yorker 440CI 89 Dodge Daytona ES 2.5L Turbo 99 Ram 2500 4X4 5.9L6
[Re: Charger69RT8]
#1195507
03/12/12 09:26 AM
03/12/12 09:26 AM
Posts: 905 SD
zrxkawboy
SD
Yes, I think it was around 240-something ci, but I could be way off. I believe it was made by Mitsubishi. If no one else posts with better info, I'll dig out an old service manual later.
It's Swifty! Swifty, you toad sucker!
[Re: dogdays]
#1195513
03/12/12 01:10 PM
03/12/12 01:10 PM
Posts: 6,018 Salem
Grizzly
Moparts Proctologist
Salem
From Wiki:
"The 1978 saw also the introduction of the first Diesel powered Dodge pickup truck. Available as an economy choice in the light duty trucks was Mitsubishi 6DR50A 4.0 L inline 6-cylinder naturally aspirating diesel, rated at 105 hp (78 kW) at 3500 rpm, and ~230 N·m (~169 lb·ft) @ 2200 rpm. The diesel used standard Dodge manual and automatic transmissions via specially made adapter plate which had the LA V8 bolt pattern. This rare factory option, VIN code H, was the result of fuel crisis and the collaboration of Chrysler and Mitsubishi. The engine, while being trustworthy and having far better economy than any other engine in the Dodge lineup at the time, suffered from its low power output and was considered to be underpowered by American standards, even though it was previously used in the Japanese 3.5-ton cab-over Mitsubishi T44 Jupiter Truck and in industrial applications. Because of the low sales it was phased out quickly and as a result it became practically a single year specialty."
Bigfoot of the late 70's Dodge truck kind. I've heard of them but never seen one.
Mo' Farts
Moderated by "tbagger".
[Re: 300by500]
#1195517
03/12/12 04:07 PM
03/12/12 04:07 PM
Posts: 2,684 Des Moines IA
Soopernaut
Des Moines IA
Many of the South American trucks had Diesels. Most are probably Perkins.
Heavier Dodge trucks had Diesels for many decades, including the 1st Cummins in 1963.
The 1st commercially available Diesel in a US market Dodge pickup was the 243 Mitsubishi in 1978.
I believe there were dealer installed Perkins engines that were used in some pickups.
1970 Dodge d100/eventually going on a 77 D100 frame
[Re: fastmark]
#1195521
03/13/12 06:10 PM
03/13/12 06:10 PM
Posts: 2,042 colorado
savoy64
colorado
chrysler has had a long diesel history---i googled dodge diesel perkins and came up with this mess----mopar belgium plant 1956-59 perkins diesels into full size chrylers--then moved production to rotterdam 1959-1962--sweden 1958 desoto plant offered perkins into full size---1963 chrysler opened their own diesel engine plant in UK then sold it to cummins in 1964----in 1960 perkins diesels were offered in Fargo pickups in canada and mexico---in 1962 dodge sold 1000 perkins in pickups in america and no one cared---in 1965 dodge offered heavy truck/military diesel options-- V6 cummins 130hp-- perkins I6 354 120hp----i had a 2 ton 1970? C600 military that served at the norad site cheyenne mountain colorado with the 354 perkins 5 speed spicer on a shortened frame with a flat bed the exhaust was routed through a 200 gallon tank of water so that the air quality wasnt ruined so fast under ground----it ran every bit as good as my modern cummins does ---also notable is it has a lower deck height than the cummins and can be mounted under a car hood----there is a ytube video of a guy running his 354 in a 65 falcon ranchero and it fits in there----sure wish i hadnt sold that truck now----bob----forgot one in 1961 jeep offered the 4 cyl perkins but chrysler didnt own amc yet----bob
