Re: What say yee of cutting motor mount pads off block?
[Re: fullmetaljacket]
#1195445
03/12/12 02:51 AM
03/12/12 02:51 AM
Posts: 2,001 s. e. pa.
calrobb2000
s. e. pa.
hi well if the block is a 75 or newe prob not as much of a loss as an older block as you will limit the reasale ability should you decide to change to a dif combo in the future . someone wanting to restore a car will not want such a block prob 95% mopars dont run plates ! look in the for sals race sections there is one there now i think ! how much weight realisticaly can you save by destroying most of costomer base that may want it after you are done with it ?? diet 2 days befor race and save some that way ??? are you trying to bracket race or set a national rechord ? food for thought
[Re: hemi-itis]
#1195448
03/12/12 09:33 AM
03/12/12 09:33 AM
fullmetaljacket
[Re: reknapp52]
#1195451
03/12/12 04:52 PM
03/12/12 04:52 PM
Posts: 1,019 Finland
mafo
Finland
my R3 blocks came without, just remember they are hard to put back if needed
-65 Valiant,420", all motor,2700#, dot tires, 8,42 @ 160,2
[Re: hemi-itis]
#1195452
03/12/12 05:23 PM
03/12/12 05:23 PM
Posts: 52,972 Romeo MI
MR_P_BODY
Worthless. I did it before. Less than 2 lbs. Doug
Doug,if you kmew this mad scientist,2 lbs is a major success
2 pounds here and there adds up quick... if you dont plan on using them for fore/aft limiters...cut them off
[Re: MRMOPAR622]
#1195455
03/12/12 07:00 PM
03/12/12 07:00 PM
Posts: 9,863 MI, usa
dvw
MI, usa
I had to grind them off when using the stock blocks in my dragster,did not hurt anything. In a race car I have always read the best way to take a 100 lbs off a race car is to find a 100 difference places to take off a 1lb.
I agree. The only problem is my car would require 500 places to make a real difference. Doug
#1195456
03/12/12 07:10 PM
03/12/12 07:10 PM
Posts: 75,070 U.S.S.A.
JohnRR
U.S.S.A.
I figured that the cylinders in those areas are probably reinforced by the presence of such bosses. What say yee?
There is water between the area the ears are and the cylinder , the cylinders are only attached at the deck and the main line bulkhead.
#1195458
03/13/12 04:25 AM
03/13/12 04:25 AM
Posts: 3,699 Newport, Mi
Evil Spirit
Newport, Mi
Probably the best dollar per pound way to take weight out of most cars...
Free advice and worth every penny... Factory trained Slinky rewinder.........
[Re: Evil Spirit]
#1195462
03/13/12 08:01 PM
03/13/12 08:01 PM
Posts: 3,396 Pa
Hot 340
Pa
I always get a kick out of the chunky guys with lexan windows.
[Re: Hot 340]
#1195463
03/13/12 08:07 PM
03/13/12 08:07 PM
MR_P_BODY
If THEY dont want to loose the weight they have to loose it some where
