Tire size question #1195185
03/11/12 04:37 PM
03/11/12 04:37 PM
STL
cdstl Offline OP
cdstl  Offline OP
STL
I have a set of Mickey Thompson L60-15" on the back of my car. It has 10.5" of tread with a 5.5" sidewall. 10.5" equates to 266 millimeters and 5.5" is 140mm. So would this tire roughly be a 260/45 15?
Also I was wondering how well these tires would fit onto an 8" wide wheel. The Centerlines on there now are at least 9" and probably 10", I bought the car this way.
thanks
1972 Cuda 340 4 speed, 2001 Ram CTD 4x4 6 speed, 1970 Duster 408 4 speed, 1996 Ram 5.9 2x4 auto, 1965 Coronet 500
Re: Tire size question [Re: cdstl] #1195186
03/11/12 04:46 PM
03/11/12 04:46 PM
Northern Pa
GLR Offline
GLR  Offline
Northern Pa
Well, years ago when they changed from the "letter" series tires to the metric style they said a 275/60-15 was the equivalent to the L60 15
If you want to go with a taller tire you can go with a 255 70 15....
if you get on to : tire rack .com you can get the spec's of what ever tire you want to compare to what you have. Hope this helps.
Re: Tire size question [Re: cdstl] #1195187
03/11/12 04:51 PM
03/11/12 04:51 PM
Kirkland, Washington
Pacnorthcuda Offline
and yes, both L60-15's and 275/60-15's can be run on an 8" wheel
Re: Tire size question [Re: cdstl] #1195188
03/11/12 11:14 PM
03/11/12 11:14 PM
STL
cdstl Offline OP
cdstl  Offline OP
STL
Thanks for the info.
Re: Tire size question [Re: cdstl] #1195189
03/12/12 02:09 AM
03/12/12 02:09 AM
Las Vegas, NV
6bblgt Offline
6bblgt  Offline
Las Vegas, NV
The "275" spec. of a p-metric tire is the section width - the widest part of the tire when mounted.
If you check your L60s you might find a few extra mms. One variable is the mounted wheel width, it is not standardized. For example, your L60s might be 265mm on a 8", 275mm on a 9", & 285mm on a 10" wheel.
