Lower control arm bushing and shaft? #1195180
03/11/12 04:14 PM
03/11/12 04:14 PM
SE Kansas
I
indytex96 Offline OP
I
SE Kansas
Trying to rebuild a friends front end on a 69 road runner and the lower control arm nut is being difficult. The shaft is turning inside the lower bushing keeping the nut from unloosening. Any tricks to this before I just cut it out and replace the whole shaft?? Thanks for any advise!
Re: Lower control arm bushing and shaft? [Re: indytex96] #1195181
03/11/12 04:28 PM
03/11/12 04:28 PM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
either the bushing is torn, or perhaps it has poly lower bushings, which will cause the piviot shaft to try and rotate, either way, remove the torsion bar, and from the back, and thru torsion bar socket of the LCA you can hammer the pin forward, tightening it up in it's bore on the K frame to try and release the nut, a little heat on the nut might help also, if the LCA bushing/pin is that bad, you might be able to pry the arm off it after pulling the torsion bar, then address the issue with the turning shaft
Re: Lower control arm bushing and shaft? [Re: DAYCLONA] #1195182
03/11/12 04:52 PM
03/11/12 04:52 PM
nj
MoJoe Offline
MoJoe  Offline
nj
I had the same problem... I removed the T bar and drove the shaft forward while prying back against the K member which gave me just enough space to grab the shoulder of the shaft with some vise grips. It left some teeth marks on the shoulder but I cleaned them up with a Dremel tool. A few shots of PB Blaster before you start helps also.
Re: Lower control arm bushing and shaft? [Re: MoJoe] #1195183
03/11/12 09:08 PM
03/11/12 09:08 PM
Northern NJ
68 Sat Offline
68 Sat  Offline
Northern NJ
I had the same problem. I used the old hammer and chisel method and replaced the shaft with firmfeels grease fitted shafts...good luck
1963 Chrysler 300 Pace Setter Convertible 21K mile survivor 1969 Dodge Coronet 500 1956 Desoto Hemi 1955 Chrysler C300
Re: Lower control arm bushing and shaft? [Re: 68 Sat] #1195184
03/11/12 11:53 PM
03/11/12 11:53 PM
Fresno, CA
Jim_Lusk Offline
Jim_Lusk  Offline
Fresno, CA
Yup, get the torsion bar out and the LCA should come off the pin. Then some vise grips and it'll be out easily.
