Vinyl Top rust repair - what's the next step? #1195161
03/11/12 03:05 PM
03/11/12 03:05 PM
Bowling Green KY / Nashville, ...
300by500 Offline OP
300by500  Offline OP
My '71 Swinger is virtually rust-free, with the exception of some areas under the vinyl top. I removed the top and took the area down to bare metal. I tried poking a small screwdriver through every one of the pits, and while most areas were solid, I ended up with about 12-13 small holes.
Re: Vinyl Top rust repair - what's the next step? [Re: 300by500] #1195162
03/11/12 03:08 PM
03/11/12 03:08 PM
300by500 Offline OP
300by500  Offline OP
This is the repair area on the passenger side...
Re: Vinyl Top rust repair - what's the next step? [Re: 300by500] #1195163
03/11/12 03:13 PM
03/11/12 03:13 PM
300by500 Offline OP
300by500  Offline OP
Since these photos, I have welded the smaller holes, and made some small patches which I welded in to fill the larger ones. Now I need to contour the welded areas and prep the areas, but what's the next step?
I want to make sure the rust doesn't come back in the small pits. I have Metal Cleaner, but it is corrosive and I don't want to damage the original paint on the other parts of the car.
Any suggestions?
Re: Vinyl Top rust repair - what's the next step? [Re: 300by500] #1195164
03/11/12 06:41 PM
03/11/12 06:41 PM
IN
ahy Offline
ahy  Offline
IN
You could paint the area with rust stop primer - I like Eastwood rust encapsulator. A brush would be fine with your orignal paint masked off. Let dry thoroughly and use some spot filler to smooth the pits. After the spot filler is dry and sanded smooth, hit it again with rust stop primer. Optional, but I would give it a final coat of enamal to seal and protect.
Re: Vinyl Top rust repair - what's the next step? [Re: ahy] #1195165
03/12/12 01:42 PM
03/12/12 01:42 PM
300by500 Offline OP
300by500  Offline OP
Ive read that Rust Encapsulator does not adhere well to bare metal.
Should I use the R-E on just the pitted areas, then use POR-15 on the clean metal? Confusing...
I want to do this job right, and only once.
Re: Vinyl Top rust repair - what's the next step? [Re: 300by500] #1195166
03/12/12 08:41 PM
03/12/12 08:41 PM
Harrisburg, Pa.
screamindriver Offline
Harrisburg, Pa.
Welding the holes is fine...Ideally you'd want to spot-blast{as in sandblast} the badly pitted area to insure the rust is completely gone inside and out but I understand what you're doing...Weld,grind, then skim-coat the area with a waterproof filler...A smooth,fiberglass filler like marglass or a product like all-metal is waterproof and are excellent choices...All-metal is tough to sand though...
I've used Eastwood's rust encapsulator also{used to be called corroless} and have had great results{better than por-15}...And it can be used over bare, even rusted metal even though you really would'nt want to do that in this case... Here's the link to make sure everyone is on the same page{ } rust encapsulator
