A518 Conversion Question #1194001
03/09/12 03:23 PM
03/09/12 03:23 PM
Wyoming, USA
1976Fury Offline OP
1976Fury  Offline OP
Wyoming, USA
I want to put an A518 Trans in my 76 plymouth fury and i cant find one in a scrapyard that is 2 wheel drive. What goes into converting a FWD transmission to a two wheel drive? Im still in highschool so buying a brand new trans is not an option. Thanks for any advice in advance.
Re: A518 Conversion Question [Re: 1976Fury] #1194002
03/09/12 03:45 PM
03/09/12 03:45 PM
Manitoba, Canada
DaytonaTurbo Offline
Manitoba, Canada
The overdrive tail shaft is different between the 2wd and 4x4 version. I think you can put a 2wd tail shaft from an A500 onto the back of an A518 but not totally sure on that. Those at least are easier to find because you can get one off of any 2wd 5.2 or 3.9 truck.
Have you tried looking in the full size vans for a 2wd 518? I've had better luck seeing them in those than the trucks which more tend to be 4x4's.
Re: A518 Conversion Question [Re: DaytonaTurbo] #1194003
03/09/12 03:50 PM
03/09/12 03:50 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
Dakotas came with them. Have you done any research on the swap? It isn't just bolt in and go. You have to have a driveshaft made and you will need to figure out a new crossmember for the trans mount. What engine do you have in the car?
Re: A518 Conversion Question [Re: stumpy] #1194004
03/09/12 04:15 PM
03/09/12 04:15 PM
Iowa, US
oldsklharo Offline
oldsklharo  Offline
Iowa, US
I am actually doing this conversion right now on my '66 Coronet.
Call around to your local salvage yards and ask for a tranny out of a 92-94 2WD Ram Truck, early to mid 90's full size Ram Van (150, 250 or 350) or the early 90's Dakota's had them as well. You want the A518/46RH. Most the time you can just reference the 46RH and they can find it from there
If you find a 4WD tranny with the transfer case attached you can buy a 2WD tail shaft off the bay for around $65 buxs. You will need to cut the bell off and buy a bolt on Ultra Bell housing from JW Racing, depending on what motor you plan on mating it to. I am putting mine behind a 383 and the part number for that is #3100.
There are a couple good "How To" threads here on the site that will walk you through everything from A to Z.
Good luck!
Re: A518 Conversion Question [Re: oldsklharo] #1194005
03/09/12 04:20 PM
03/09/12 04:20 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
Does this $65 tail include the OD unit ? if so that's a DEAL ...
Re: A518 Conversion Question [Re: JohnRR] #1194006
03/09/12 04:21 PM
03/09/12 04:21 PM
Iowa, US
oldsklharo Offline
oldsklharo  Offline
Iowa, US
Yep but it's already been sold. I almost bought it just to have around
Here is a great post that should answer most your questions........
https://board.moparts.org/ubbthreads/show...t=1#Post5718201
Re: A518 Conversion Question [Re: oldsklharo] #1194007
03/09/12 10:02 PM
03/09/12 10:02 PM
Wyoming, USA
1976Fury Offline OP
1976Fury  Offline OP
Wyoming, USA
thanks a million and its going behind a 360
Re: A518 Conversion Question [Re: 1976Fury] #1194008
03/09/12 10:41 PM
03/09/12 10:41 PM
Wyoming, USA
1976Fury Offline OP
1976Fury  Offline OP
Wyoming, USA
Ive been doin some serious googling and some say the output shaft is too short to just bolt on a new tailshaft. Is this true or was i mislead?
Re: A518 Conversion Question [Re: 1976Fury] #1194009
03/10/12 12:35 AM
03/10/12 12:35 AM
Missouri U.S.A.
71yelladustr Offline
Missouri U.S.A.
Output shafts do not interchange. The intermediate shafts are the same tho.
392 gen III hemi on E-85 727 trans Dana 60
10.02@134
Re: A518 Conversion Question [Re: 71yelladustr] #1194010
03/10/12 12:56 AM
03/10/12 12:56 AM
colorado
savoy64 Offline
savoy64  Offline
colorado
output smoutput-----the overdrive units 2w---4w just bolt off and on--sometimes if luck is with you it will function ok----to do it right the tranny might have to be rebuilt to adjust the tolerances from the overdrive forward-there is a thrust type washer in the overdrive in about 5 different thicknesses that is used to adjust the tolerance in the maincase--do not disassemble the overdrive unit as there is a spring in there that can cause serious injury--bob
Re: A518 Conversion Question [Re: 1976Fury] #1194011
03/10/12 01:29 AM
03/10/12 01:29 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
On the OD trans the OD is inside part of the tail housing , you need to have the entire tailhousing with OD inside it ... most parts are the same , the output shaft of the OD unit itself is different ... and you aren't going to be finding it for 65 bucks unless it's junk .
Re: A518 Conversion Question [Re: JohnRR] #1194012
03/10/12 11:08 AM
03/10/12 11:08 AM
Crofton, MD
bri440 Offline
bri440  Offline
Crofton, MD
I did this swap in a 71 Challenger. Do yourself a favor - find a RWD transmission. There are so many other problems you are going to have to chase, don't add this to your list. Things that you are already going to have to deal with are:
1) Rework the shift linkage. The OD unit interferred with the mechaical linkage - I went to a cable set-up.
2) Change the driveshaft length. You also need to swap yokes.
3) Rework the transmission mount and crossmember.
4) Rework the bell housing connection - either with a JW ultra bell or a JVX Adapter. I went with the JVX.
5) Lengthen the spedometer cable
6) Maybe modify your transmission tunnel. I had to modify the tunnel frame and some sheet metal to get the engine/trans to sit level.
7) I made new trans cooler lines, went to 3/8". Not positive it was necessary, but I read it was and seemed easy enough. Also added another cooler up front.
8) Add the electrical wiring and the pressure switches for the OD and lock-up controls.
Aside from the RAM trucks look at vans and service vehicles.
Good luck
Re: A518 Conversion Question [Re: bri440] #1194013
03/13/12 01:52 PM
03/13/12 01:52 PM
Wyoming, USA
1976Fury Offline OP
1976Fury  Offline OP
Wyoming, USA
Thanks a million guys i probly would have gotten into some serious trouble So i will look around for aa trans out of a b150/250/350 van and see what i can come up with. This new trans is bolting up to a 360 samll block would i still need the adaptor plate for the bell housing?
Re: A518 Conversion Question [Re: 1976Fury] #1194014
03/13/12 02:13 PM
03/13/12 02:13 PM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
No adapter needed to bolt to a smallblock..
Re: A518 Conversion Question [Re: 1976Fury] #1194015
03/13/12 02:14 PM
03/13/12 02:14 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
No you won't need an adapter.
Re: A518 Conversion Question [Re: stumpy] #1194016
03/20/12 09:38 PM
03/20/12 09:38 PM
Wyoming, USA
1976Fury Offline OP
1976Fury  Offline OP
Wyoming, USA
okay so found a 1996 Dodge 1500 V6. If im correct it has a A500 trans in it. Think with a rebuild it will hold up to a 360 with a decent cam in it? If not will the tailshaft bolt to a A518?
Re: A518 Conversion Question [Re: 1976Fury] #1194017
03/20/12 10:06 PM
03/20/12 10:06 PM
SoMd, USA
135sohc Offline
135sohc  Offline
SoMd, USA
96 is the RE (electronically controlled) transmission. 95 & older for the RH transmission.
Re: A518 Conversion Question [Re: 135sohc] #1194018
03/20/12 10:12 PM
03/20/12 10:12 PM
Wyoming, USA
1976Fury Offline OP
1976Fury  Offline OP
Wyoming, USA
Can i still salvage the tail shaft housing with OD unit and put on a older A518
Re: A518 Conversion Question [Re: 1976Fury] #1194019
03/21/12 01:45 AM
03/21/12 01:45 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
No , there is no govenor in the back of the OD unit .
Re: A518 Conversion Question [Re: JohnRR] #1194020
03/21/12 12:11 PM
03/21/12 12:11 PM
colorado
savoy64 Offline
savoy64  Offline
colorado
also the hydraulic o/d is operated by hydraulic---the electric o/d is operated by electric and the electric housing is about 1 inch shorter---bob
