I have a Mopar 3690430 distributor and it has a very quick and small mechanical advance that doesn't seem to be in line with the instructions I've found for it. I have my initial set at 10 degrees at 750 rpm. Mechanical advance seems to start around 1000 rpm. By 1100 I have 12 degrees 16 degrees at 1200 18 degrees at 1400 22 degrees at 1600
And then that's it. 12 degrees of mechanical advance. I tried twisting the rotor and it seems to have one light-ish spring and one HEAVY spring. I took my idle up as far as my underhood dwell tach box would go (2000 rpm) and then a bit further and it just sat on 22 degrees without a hint of creeping. I dunno where the rest of this advance is coming in but it's somewhere where I don't like my head under the hood. Even the instruction PDF for this distributor that I've found in a couple of places suggests mechanical should be all-in by 2000-2500. I took a look at the position of the pins in the slots when I hit the beginning of the heavy spring and it looks like it has around half as much advance left.
Were these things ever set up with this kind of a curve? I've peeked through the openings in the top plate and it doesn't look like it's been messed with, but the rotor is stuck fast to the shaft so that's about all I can tell right now.
1967 Dodge Coronet Deluxe station wagon
1.03" T-bars, QA1 arms/rods, Cordoba/GM Metric/Volare brake & knuckle, XHDs, Hellwig rear sway, 318 Magnum w/ air gap, 727, 3.23s
