Firm Feel box vs shimming the PS pump
#1193527
03/08/12 07:48 PM
03/08/12 07:48 PM
Posts: 28,067 Irving, TX
feets
Senior Management
Senior Management
Irving, TX
What is the difference between a Firm Feel box and a regular steering box? Is it just the required effort? Can you get a typical rebuilt box and shim the pump pressure valve and accomplish the same thing for less money?
Re: Firm Feel box vs shimming the PS pump
[Re: feets]
#1193528
03/08/12 11:13 PM
03/08/12 11:13 PM
moparpollack
Lil Herman
Lil Herman
85086
Everyone likes the cost of the shim deal and the FF is expensive because of the shipping cost. Why not try the cheap first?
[Re: moparpollack]
#1193529
03/09/12 02:17 AM
03/09/12 02:17 AM
feets
Senior Management
Senior Management
Irving, TX
I never understood the reason to pay for a new box (or additional upgrade) if all they're doing is reducing line pressure.
Is there anything else different in the box?
[Re: feets]
#1193530
03/09/12 02:32 AM
03/09/12 02:32 AM
1_WILD_RT
Management Trainee
Management Trainee
Today? Who Knows?
You can not reduce pressure in the gear box, instead they increase the stiffness of the reaction springs, the reaction springs essentially act as the control valves as the steering wheel is turned it causes one or the other reaction spring to deflect which shifts the spool in the control valve... Full pump pressure is still used...
The shim trick reduces pressure and since pressure & flow are tied to one another the reduced volume causes a reduction in assist... It works but in the hydraulic field it's not considered the right way of reducing assist...
[Re: 1_WILD_RT]
#1193531
03/09/12 09:08 AM
03/09/12 09:08 AM
Posts: 1,756 London, England
Gavin
London, England
The short answer to your question is this (from FF website) "All FFI Power Steering boxes are thoroughly cleaned and inspected, the cases are machined for roller bearing sector supports and the worm gear assemblies are resized, the box is then fitted with Firm Feel's exclusive reaction springs"
The typical parts store rebuilds don't do the machining, resizing etc. So IMHO the best reason for getting a FF box is actually the first part of that sentence - that you get a properly rebuilt box. The second bit (the firmness/reaction spring etc) is also something I want, but I'd rather have a stock-effort box that is tight than a sloppy firm box (actually I want both but you get my point)
If you have a box that is in great shape, no slop etc, then do the washer thing and enjoy!
[Re: Gavin]
#1193532
03/09/12 02:29 PM
03/09/12 02:29 PM
1_WILD_RT
Management Trainee
Management Trainee
Today? Who Knows?
That is a little deceptive... Most boxes already had a roller bearing sector support, the only boxes that don't are early A body boxes...
[Re: 1_WILD_RT]
#1193533
03/09/12 03:11 PM
03/09/12 03:11 PM
Posts: 199 NC
1970A66
NC
I agree with Gavin and Wild RT ^^
So........I just installed a FF Stage 2 box in January, because my original was way loose inside. I also just did the shim mod to my Saginaw PS pump 2 weeks ago.
According to Mopar Action magazine and as stated above, if your gear box is good and tight, as well as everything else under the car(though doubtful after 40 years) try the shim mod.
I bought the FF box because of all the positive reviews especially from Mopar Action tech editor Rick Ehrenberg who posts on here. It made a day/night difference in the car handling/feel. Worth the money for sure. Every other steering and suspension part was already new.
Now, I still wanted a better road feel similar to my every day modern car so I did the shim mod. I went from .065 to .105 thick shim/washers. WOW.....another step change for the better!! The steering wheel has a heavier feel, feels very much like my Acura. I actually may try .125 shim for more feel.
The added shim eliminates the over assist twitchy stock feel.
[Re: 1970A66]
#1193534
03/11/12 07:57 PM
03/11/12 07:57 PM
Posts: 3,884 Oregon
hooziewhatsit
Are stiffer springs something we could do ourselves? I emailed FF a while back and they said they don't work on truck boxes...
[Re: feets]
#1193538
03/13/12 12:36 AM
03/13/12 12:36 AM
Posts: 5,439 So Cal
Sinitro
So Cal
One word of caution about dealing with Firm Feel... I bought a box from them, installed it and it leaked.... When I contacted them about shipping it back, the guy on the phone was very arrogant and had a major attitude problem.. They wanted me to pay the freight for sending the box back while telling me it would take at least a week to check it out and get back to me... Meantime I had the car torn apart plus the lost time/labor switching out boxes... Suffice it to say I have never dealt with Firm Feel again.. And I am glad there are other vendors that sell comparable products for our Mopars and care about the customer. Just my $0.02...
[Re: Sinitro]
#1193542
03/18/12 06:22 PM
03/18/12 06:22 PM
Posts: 817 Eugene, Oregon
Secret Chimp
Eugene, Oregon
Just my $0.02...
You're probably not the first person who had a leak. Leaks are probably far more common due to installation mistakes versus workmanship mistakes, and they've probably been burned in the past from people claiming to have leaky boxes, comping the freight back, only to find the dummy cross-threaded a line fitting or something and lied about it on the phone.
If I was running this business I wouldn't have jumped to take the box back either. Try seeing it from their side.
1967 Dodge Coronet Deluxe station wagon
1.03" T-bars, QA1 arms/rods, Cordoba/GM Metric/Volare brake & knuckle, XHDs, Hellwig rear sway, 318 Magnum w/ air gap, 727, 3.23s
[Re: HotRodDave]
#1193543
03/18/12 07:01 PM
03/18/12 07:01 PM
Posts: 5,439 So Cal
Sinitro
So Cal
Just my $0.02...
Do you expect them to get you a rental car? No vendor will do that for you and very few will pay to ship it back either or the labor time to swap it. I run a very busy full service auto repair shop and anytime we have a parts failure under warranty I have to pay the labor for the warranty even if it is clearly the vendors fault. I file labor claims all the time and only one time in all my years of service did I get any labor money from the vendor. Also about the shipping, it is not there fault you live a long ways from where you bought the part, why should they have to pay shipping? It is nice when a vendor does that but not required.
I can not argue wheather or not he had a bad atitude, mabey his brother just died or... or mabey he is just mean that sounds like your only good complaint.
I expect them to stand behind their products.. Another point is that since I was getting the car ready for a show, I needed the box shipped by 2-day air which was @ a much higher $ rate.
Together with the cost of box and 2-day air charges we spent almost $600 not counting my time, and his BS response was to send it back at my cost which would have been another $100..
Don't think so, today we have other vendor choices and when we bought/installed a competitor's product they actually shipped it next day @ their cost. And it didn't leak..
I will not accept his BS attitude, and if I was located close by his shop, he would have received back the box tossed through his front window..
I didn't expect compensation for my labor but expected they could of at least supplied me a replacement instead of a leaking box and a pile of BS.. I have worked in a customer service envoirment for many years and would never have treated a customer his rude way. There are ways of handling returns without all of the drama..
I just hope others don't have to go through the same.
Just my $0.02..
[Re: Sinitro]
#1193545
03/19/12 04:05 AM
03/19/12 04:05 AM
Secret Chimp
Eugene, Oregon
Just my $0.02...
Just my $0.02..
Who the heck shipped you a custom power steering gearbox via next day air on their dime?
