What's the name/purpous of this valve? #1193018
03/07/12 08:32 PM
03/07/12 08:32 PM
Elk Grove, Calif.
bigblock340power Offline OP
Elk Grove, Calif.
I just got done rebuilding the 2 bbl carb on my truck. This valve is not holding vacuum. But I don't know where to get another one, or even what it does or what it's called. It's the one on the far left with the hose still on it, and linked to the choke arm (oh, and these pics were taken before I rebuilt the carb).
A little help here please.
Re: What's the name/purpous of this valve? [Re: bigblock340power] #1193019
03/07/12 08:40 PM
03/07/12 08:40 PM
Slidell, LA
Ronnman Offline
Ronnman  Offline
Slidell, LA
It is the choke pull off pot/diaphragm. It's purpose is to slightly open the choke butterfly after the engine starts to help prevent an over rich condition. It might be available at some auto parts stores.
Ron
Re: What's the name/purpous of this valve? [Re: bigblock340power] #1193020
03/07/12 08:40 PM
03/07/12 08:40 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
It's called a choke pull-off. It pulls the choke butterfly open against the closing force of the choke thermostat.
Re: What's the name/purpous of this valve? [Re: bigblock340power] #1193021
03/07/12 08:43 PM
03/07/12 08:43 PM
PA
maxwedge1 Offline
maxwedge1  Offline
PA
choke vacuum actuator
Re: What's the name/purpous of this valve? [Re: maxwedge1] #1193022
03/07/12 08:47 PM
03/07/12 08:47 PM
Slidell, LA
Ronnman Offline
Ronnman  Offline
Slidell, LA
Available at Rockauto. STANDARD MOTOR PRODUCTS Part # CPA66 More Info {#2585416, 2808042, 2809369, 2809388, 2809389, 3419508, 3419511, 3549450, 3621272, 3683807, 3683874, 3685730, 3685731, 3685732, 3685733, 3685846, 3744549, 3744550, 3879116, 443807C2, 460750C1, 465112C1, 465113C1}
Choke Pulloff 2 BBL
Re: What's the name/purpous of this valve? [Re: Ronnman] #1193023
03/07/12 08:51 PM
03/07/12 08:51 PM
Elk Grove, Calif.
Elk Grove, Calif.
Would this cause a vacuum leak, 'cause it won't hold vacuum?
You people are the best.
Re: What's the name/purpous of this valve? [Re: bigblock340power] #1193024
03/07/12 08:53 PM
03/07/12 08:53 PM
Slidell, LA
Ronnman Offline
Ronnman  Offline
Slidell, LA
Yes
Re: What's the name/purpous of this valve? [Re: Ronnman] #1193025
03/07/12 09:04 PM
03/07/12 09:04 PM
Elk Grove, Calif.
Elk Grove, Calif.
Yes
Well I've got that port capped off with a rubber cap for now. Seems to run a bit better. I ordered a new one, will be in tomorrow a 1:00.
Thanks again all.
Re: What's the name/purpous of this valve? [Re: bigblock340power] #1193026
03/08/12 08:33 AM
03/08/12 08:33 AM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
New ones also need adjusted when installed.Those I believe you use a drill in between the choke and carb body and pull vacuum on the pull off.Then the arm gets bent.Sometimes you get lucy and its real close.Been years since I did them.Used to have angle gauges and different size bits to set them at work.Rocky
Chrysler Firepower
Re: What's the name/purpous of this valve? [Re: bigblock340power] #1193027
03/08/12 10:03 AM
03/08/12 10:03 AM
chicagoland,usa
buildanother Offline
chicagoland,usa
Agreed with above, and you'd be sunk w/out that thing working in a cold climate.
Re: What's the name/purpous of this valve? [Re: buildanother] #1193028
03/08/12 10:55 AM
03/08/12 10:55 AM
Elk Grove, Calif.
Elk Grove, Calif.
Yah, I get it. But Calif.?
Re: What's the name/purpous of this valve? [Re: bigblock340power] #1193029
03/08/12 11:00 AM
03/08/12 11:00 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
That valve also pulls open the choke plate under part throttle conditions till the choke thermo pulls it completely open once the engine is warmed up .
Re: What's the name/purpous of this valve? [Re: bigblock340power] #1193030
03/08/12 08:30 PM
03/08/12 08:30 PM
santa anna, Tx.
charles6970 Offline
charles6970  Offline
santa anna, Tx.
i see two vaccum valves,
which one are you talking about??
Re: What's the name/purpous of this valve? [Re: charles6970] #1193031
03/08/12 08:59 PM
03/08/12 08:59 PM
Elk Grove, Calif.
Elk Grove, Calif.
Thank you all for your help. I have replaced the choke pull off valve (see, I know what to call it now), and all is right with the world again.
As far as "which one are am I talking about"? I think the part about " It's the one on the far left with the hose still on it" should have cleared it up nicely.
Re: What's the name/purpous of this valve? [Re: bigblock340power] #1193032
03/09/12 04:56 AM
03/09/12 04:56 AM
PNW
Danan Offline
Danan  Offline
PNW
Hey Mike,
If you move to WA I'll give you an Edelbrock RPM and a holley 4bbl all ready to go! Oh, and a completely rebuilt 9 1/4" rear with aftermarket shafts, new gears/bearings. But you have to MOVE, not visit. Heck; I'll give you the entire 360 engine, recently rebuilt and complete.
Did I forget to mention that we have no smog laws and that because WA is in the United States of America, the 2nd Amendment pertains so you can actually own firearms??
Re: What's the name/purpous of this valve? [Re: charles6970] #1193033
03/09/12 05:17 AM
03/09/12 05:17 AM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
Yes I see 2 vacum valves also. The one at the back of the carb is the choke pull-off and the one close to the front looks like an AC idle up valve. Ron
Re: What's the name/purpous of this valve? [Re: 383man] #1193034
03/09/12 07:30 AM
03/09/12 07:30 AM
Out in Left Field, NY
bobs66440 Offline
bobs66440  Offline
Man! What a contraption Can you imagine engineering that from scratch?
Re: What's the name/purpous of this valve? [Re: Danan] #1193035
03/09/12 10:45 AM
03/09/12 10:45 AM
Elk Grove, Calif.
Elk Grove, Calif.
Hey Mike,
Damn Danan, you make it tempting.
All I'd have to do is retire early (live on a diminished income), sell everything at a loss ('cause the economy sucks right now), move away from every bit of family we have, and move everything 12 hours 41 mins/750.2 mi to the north. I think I'll wait it out.
By the way, how you doing? No hear from for quite a while (WTF). Everyones been asking (I have nothing to give them)!
Re: What's the name/purpous of this valve? [Re: bigblock340power] #1193036
03/10/12 03:55 AM
03/10/12 03:55 AM
PNW
Danan Offline
Danan  Offline
PNW
Mike,
EVERYONE lives on a diminished income in WA; you'll fit right in. Did I forget to mention that the 360 has an actual 9:1 compression ratio so it'll actually get out of it's own way?
Things are going well overall. Good days and bad days, as you would expect. Doing a lot of good things and there isn't another place I'd rather be right now. I'm happier doing what I do over here than anything I could do back in the States; especially during an election year.
Send my best to the family and all our buds. Also, I'll be seeing you guys in the not-so-distant future. By the way, how many guys show up to coffee these days??
Re: What's the name/purpous of this valve? [Re: Danan] #1193037
03/10/12 11:25 AM
03/10/12 11:25 AM
Elk Grove, Calif.
Elk Grove, Calif.
Well, I guess since this is our only venue for talking now a days. I'd say about six or so off and on. All are doing fine. I haven't heard a word fron your Mrs. in quite a while. All OK?
