Distributer lower plastic collar / bushing #1192717
03/07/12 01:55 AM
03/07/12 01:55 AM
Alaska
73rrak Offline OP
73rrak  Offline OP
Alaska
I broke my last plastic bushing/ collar at the bas of the distributer.
This is the the collar that the pin goes thru on the shaft at the bottom of the distributer housing. Does anybody sell them like NAPA Autozone ?
Does anybody know what kind of material they are made out of? I have some teflon and UHMW plastic here if that will work to make one but I would prefer to just buy one if I can
Re: Distributer lower plastic collar / bushing [Re: 73rrak] #1192718
03/07/12 02:04 AM
03/07/12 02:04 AM
Go to the Lowes nut and bolt section.
They have a nylon collar that is sold by Hillman that is the PERFECT size. 99 cents if I recall correctly.
You will have to drill it, but I like to set my own end-play anyway.
Re: Distributer lower plastic collar / bushing #1192719
03/07/12 08:22 AM
03/07/12 08:22 AM
Alaska
73rrak Offline OP
73rrak  Offline OP
Alaska
WOW !!!! perfect thank you !! I will get one later today
