Re: 440 Six Pack Vibration w/ Neutral Bal Torque Converter?
[Re: JohnRR]
#1192252
03/06/12 02:52 PM
03/06/12 02:52 PM
Posts: 3,624 Fort Worth, Texas
xs29j8
Fort Worth, Texas
You would have a noticeable vibration at idle and all speeds , does it still have the external balancer on the front ?
Yes, the correct external balancer is there. It is possible to neutral balance them tho, would have to check the back side of the damper.
No vibration at idle, maybe a slight vibration while revving the engine... not severe.
[Re: Cab_Burge]
#1192254
03/06/12 03:33 PM
03/06/12 03:33 PM
xs29j8
Fort Worth, Texas
The vibrations come and go at different RPM, I've had two motors that had the correct dampener and the incorrect converters, one motorhome motor and one 1971 U code HP motor with the big rods
Any vibration at idle? IIRC, there was some vibration between 2500-3000 RPM while revving in neutral...
[Re: xs29j8]
#1192256
03/06/12 05:21 PM
03/06/12 05:21 PM
Posts: 75,015 U.S.S.A.
JohnRR
U.S.S.A.
A 440-6 should have a weighted convertor , the fact that it has the correct balancer points to it being internal balance though it could be internal balance. I have seen a 6pk dampner drilled to make it internal balnce and still have the look , you could pull it or use a mirror to look it over real well to see if it has a large amount of holes drilled 180 from the weight.
I did have a 440 with 6pk rods and heavy TRW 6pak replacement internal balnced internal balanced with just a small amount of steel added to the crank , I imagine someone could balance the crank to use the weighted dampner on the front and no weights on the rear but the only way you are going to figure that out is to talk to the shop that did the work originally or pull it out and have it checked .
[Re: JohnRR]
#1192257
03/06/12 06:41 PM
03/06/12 06:41 PM
xs29j8
Fort Worth, Texas
Thanks for the replies! The mechanic called to say it looks all original inside, big rods with no signs of internal balancing. Photos to be emailed later this evening...
I guess the `Cuda had more than one "Shaker" for the last 30+ years... Very mild vibration tho...
[Re: dogdays]
#1192259
03/06/12 07:26 PM
03/06/12 07:26 PM
JohnRR
U.S.S.A.
Sounds like all you need is the correctly imbalanced flexplate to have a goer. R.
, hopefully nothing got hurt from the imbalance . The 383 in my dart had what I believe was a 360 130tooth flywheel on it for I don't know how long , had a vibration , I change the clutch and had the flywheel check and rebalanced , it still has a vibration but I'm not sure now how well the imbalance was corrected considering the shop that did it missed on my stroker crank balance when I had it checked .
[Re: JohnRR]
#1192260
03/06/12 09:21 PM
03/06/12 09:21 PM
xs29j8
Fort Worth, Texas
Currently planning to use the B&M 10238 flexpate:
http://bmracing.com/?wpsc-product=chrysler-sfi-flexplate-70-up-chrysler-4404-wtf727
...concerned about the .008 TIR engine to transmission requirement for installation tho...
Pics just received:
[Re: xs29j8]
#1192264
03/07/12 01:35 AM
03/07/12 01:35 AM
JohnRR
U.S.S.A.
Pics just received:
Is it the original trans ? if so the TIR shouldn't be an issue .
[Re: JohnRR]
#1192265
03/07/12 03:05 AM
03/07/12 03:05 AM
xs29j8
Fort Worth, Texas
Pics just received:
No, the transmission is not the orginal... or even the correct P/N or year of make. So far, no luck in my search for a Six Pack P/N transmission...
I believe the engine is fine... the main bearings might have been hammered a bit, but the oil pressure is good even at hot idle conditions. My plans to rebuild the engine are more about wanting an extra 100 HP than the condition, but this issue gives it a bit more urgency...
[Re: xs29j8]
#1192269
03/08/12 02:20 AM
03/08/12 02:20 AM
Posts: 43,190 Bend,OR USA
Cab_Burge
Get the right converter Or get the add on weight kit for your converter and have them welded on
