Page 1 of 3 1 2 3
Difference between the 392 and 426 Hemi's????? #1191544
03/05/12 01:10 PM
03/05/12 01:10 PM
Iowa, US
oldsklharo Offline OP
Iowa, US
What are the main differences between the two? Are the blocks the same but with different bore and crank?
I have an opportunity to pick up a 392 for a good price and want to be educated on the two before I put all my eggs into on basket. Any info would be great
Thanks, Mike
Re: Difference between the 392 and 426 Hemi's????? [Re: oldsklharo] #1191545
03/05/12 01:12 PM
03/05/12 01:12 PM
albany ny
0
05dakota Offline
05dakota  Offline
albany ny
TOTALLY DIFFERENT.
5549 post on old board
Re: Difference between the 392 and 426 Hemi's????? [Re: 05dakota] #1191546
03/05/12 01:13 PM
03/05/12 01:13 PM
Iowa, US
Iowa, US
TOTALLY DIFFERENT.
In what ways?
Re: Difference between the 392 and 426 Hemi's????? [Re: oldsklharo] #1191547
03/05/12 01:15 PM
03/05/12 01:15 PM
s.w.fl
bonefish Offline
bonefish  Offline
s.w.fl
for one the dist is in the back on a 392.
Re: Difference between the 392 and 426 Hemi's????? [Re: bonefish] #1191548
03/05/12 01:15 PM
03/05/12 01:15 PM
albany ny
0
05dakota Offline
05dakota  Offline
albany ny
they have nothing in common
Re: Difference between the 392 and 426 Hemi's????? [Re: 05dakota] #1191549
03/05/12 01:17 PM
03/05/12 01:17 PM
Iowa, US
Iowa, US
Ok, would picking up a complete 392 engine and tranny for under $3,000 be worth it?? I Have to think it would be but I am not completely sure......
Re: Difference between the 392 and 426 Hemi's????? [Re: 05dakota] #1191550
03/05/12 01:18 PM
03/05/12 01:18 PM
Spokane Washington
ScottSmith_Harms Offline
Mr Wizzard
Mr Wizzard
Spokane Washington
Completely different engines but a 392 is a great engine.Whats A "good deal"? Better be sure its a 392 a lot of lesser 50s hemis look alike.
Re: Difference between the 392 and 426 Hemi's????? [Re: oldsklharo] #1191551
03/05/12 01:19 PM
03/05/12 01:19 PM
albany ny
0
05dakota Offline
05dakota  Offline
albany ny
in my opinion no, unless you own a street rod or lates 50s car that had 1 orginally
Re: Difference between the 392 and 426 Hemi's????? [Re: ScottSmith_Harms] #1191552
03/05/12 01:21 PM
03/05/12 01:21 PM
Iowa, US
Iowa, US
Completely differwnt engines but a 392 is a great engine.Whats A "good deal"? Better be sure its a 392 a lot of lesser 50s hemis look alike.
I guess a "good deal" would be $2500-$2800? I have never bought a 392 before and honestly can't afford a 426 so I figured a 392 would be the next best thing. It would be going in my '66 Coronet Vert. My car is far from stock, more like a resto mod
Re: Difference between the 392 and 426 Hemi's????? [Re: 05dakota] #1191553
03/05/12 01:24 PM
03/05/12 01:24 PM
s.w.fl
bonefish Offline
bonefish  Offline
s.w.fl
i see them now and then in unknown condish and they usually go for between 1,000 to 1,500.you can get the trannies for free .
Re: Difference between the 392 and 426 Hemi's????? [Re: bonefish] #1191554
03/05/12 01:27 PM
03/05/12 01:27 PM
Iowa, US
Iowa, US
Thanks what I needed to know...... thanks for the info. Guess I may not pursue this one but now have a better understanding up what price range to look for
Re: Difference between the 392 and 426 Hemi's????? [Re: 05dakota] #1191555
03/05/12 01:43 PM
03/05/12 01:43 PM
dogdays Offline
dogdays  Offline
The 392 is a raised deck version of the original Chrysler Firepower Hemi and as such has bore spacing 4.5625". It is a lot closer in design to the A/LA engines than to the B engines. A 426 Hemi is an RB engine, that's a B engine with a raised deck. Bore spacing is 4.80".
The only thing the 426 and 392 have in common is that they were based on a raised deck version of a previous block series, and that's a words-only similarity.
The other major pitfall for you and this engine purchase is that from the outside it is very hard to tell a 392 from the much more common 354 or 331. There is a code I believe stamped onto the top valley rail that will tell you what the engine is and where it's from.
Do a Google search for Chrysler Hemi and you'll find the chart. Lots of information is on the Web.
Now on to this particular engine - once you determine that it's a 392. Here are my top five reasons to buy a 392:
1. It's one of the coolest looking engines ever made.
2. You own an early letter series Chrysler and want to give it a boost in power.
3. You have a nostalgia dragster and need a 392 to make it right.
4. You have a spare '34 couope body lying around and want to build a traditional hot rod.
5. You have a big wad of cash burning a hole in your pocket and you always wanted a Hemi.
If you want to see what it would cost to rebuild a Hemi go to PAW or www.hothemiheads.com. They ain't cheap!
For $3000 this engine would have to be guaranteed to be rebuildable, like pass Magnaflux and crank and bore sizes are within reason. Even a fresh rebuild would need to be gone through because there are good parts and crappy parts.....
Also I think that price is more of a speculative price, much like the $2500 barn fresh DeSoto or Dodge hemis I see on Craigslist every now and then.
Good Luck!
R.
Re: Difference between the 392 and 426 Hemi's????? [Re: oldsklharo] #1191556
03/05/12 01:47 PM
03/05/12 01:47 PM
s.w.fl
bonefish Offline
bonefish  Offline
s.w.fl
have you tried talkin the guy down.if i was lookin and found one with all the accesaries attached and the matching trans and vert.2grand wouldnt be out of the question.
Re: Difference between the 392 and 426 Hemi's????? [Re: bonefish] #1191557
03/05/12 01:57 PM
03/05/12 01:57 PM
Finally a HUSKER again
Moparnut426 Offline
Moparnut426  Offline
Just breezing through this thread, but from what I know, and see, and understand, the 392s 354s, 331s, were more like the LA small blocks than that of any big block. I even think the timming chain sets of a small block POLY 318 are the same. Dont know for sure, but seem to remember a friend of mine who has a blown 392 for a rat rod project telling me that.
Kasey
Re: Difference between the 392 and 426 Hemi's????? [Re: Moparnut426] #1191558
03/05/12 02:01 PM
03/05/12 02:01 PM
Iowa, US
Iowa, US
dogdays, wow that is some great info! Thanks
bonefish, I have not talked to the guy but if I found it was worth my while I was going to call him. I guess I'll give him a call and see what I can work out. All he can say is no!
Re: Difference between the 392 and 426 Hemi's????? [Re: oldsklharo] #1191559
03/05/12 02:03 PM
03/05/12 02:03 PM
Iowa, US
Iowa, US
Was '58 the last year for the 392?
Looks like they put out 390hp and 435 lb-ft. That would make my Coronet scream!
Re: Difference between the 392 and 426 Hemi's????? [Re: oldsklharo] #1191560
03/05/12 02:26 PM
03/05/12 02:26 PM
beedees Offline
beedees  Offline
What year model are you talking about?
Re: Difference between the 392 and 426 Hemi's????? [Re: beedees] #1191561
03/05/12 02:29 PM
03/05/12 02:29 PM
Iowa, US
Iowa, US
'58
Re: Difference between the 392 and 426 Hemi's????? [Re: oldsklharo] #1191562
03/05/12 02:36 PM
03/05/12 02:36 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
You can get that out of a 440 for a lot less money .
Re: Difference between the 392 and 426 Hemi's????? [Re: JohnRR] #1191563
03/05/12 02:44 PM
03/05/12 02:44 PM
Iowa, US
Iowa, US
Ya but it's a Hemi. I know it may sound superficial and I have a hard running 383 in it now that probably puts out close to those numbers but have always wanted a Hemi and can't afford a 426.
I just recently picked up a 2003 5.7 Hemi to do a conversion but am having second thoughts. I really like the old school carburated BB's though
Page 1 of 3 1 2 3
