70 Challenger 3 speed wiper - motor, switch,harness ? #1191128
03/04/12 06:48 PM
03/04/12 06:48 PM
moparmedic Offline OP
I have a 70 Challenger that I pretty much bought in parts. The dash was in the car as was the wiper motor and switch and all the wiring appeared to be hooked up. The fender tag says it is supposed to have 3 spd wipers. When I took it all apart to clean and paint the dash frame I found that the wiper switch only clicks to the right twice but the motor looks like a 3 speed motor. Is the dash harness the same for 2 and 3 speed motors regardless which motor you have? I am thinking someone may have swapped out the switch panel.
1968 Coronet
1968 Charger
1966 A100 Pickup
1967 Barracuda
1970 Challenger
1972 Challenger
1973 Barracuda
2021 Ram 2500
Re: 70 Challenger 3 speed wiper - motor, switch,harness ? [Re: moparmedic] #1191129
03/04/12 07:10 PM
03/04/12 07:10 PM
Montreal,Quebec,Canada
JulesdaWiperman Offline
super gas
super gas
Yes.
Check to see if your wiper motor dash swwitch plugs are like this.
Jules
Re: 70 Challenger 3 speed wiper - motor, switch,harness ? [Re: JulesdaWiperman] #1191130
03/04/12 07:17 PM
03/04/12 07:17 PM
Yes, that is what my harness looks like.
Maybe I made an error on the codes.
The harness on the wiper motor motor is set up like what the shop manual shows for a two speed. Is there an obvious difference between a 2 and 3 speed motor on the E Bodies? The two speed in my Charger is totally different but the 3 speed in my 73 barracuda looks similar.
1968 Coronet
1968 Charger
1966 A100 Pickup
1967 Barracuda
1970 Challenger
1972 Challenger
1973 Barracuda
2021 Ram 2500
Re: 70 Challenger 3 speed wiper - motor, switch,harness ? [Re: moparmedic] #1191131
03/04/12 11:08 PM
03/04/12 11:08 PM
super gas
super gas
2 speed E body
Re: 70 Challenger 3 speed wiper - motor, switch,harness ? [Re: moparmedic] #1191132
03/04/12 11:10 PM
03/04/12 11:10 PM
super gas
super gas
3 speed E body
Re: 70 Challenger 3 speed wiper - motor, switch,harness ? [Re: JulesdaWiperman] #1191133
03/04/12 11:52 PM
03/04/12 11:52 PM
Thanks Jules! I thought so but wasn't 100% sure. So I have a 3 speed motor and a two speed switch, that's just great!
1968 Coronet
1968 Charger
1966 A100 Pickup
1967 Barracuda
1970 Challenger
1972 Challenger
1973 Barracuda
2021 Ram 2500
Re: 70 Challenger 3 speed wiper - motor, switch,harness ? [Re: moparmedic] #1191134
03/05/12 10:28 AM
03/05/12 10:28 AM
super gas
super gas
For 70 you need a variable speed switch that ends with part number 380.
Jules
Re: 70 Challenger 3 speed wiper - motor, switch,harness ? [Re: JulesdaWiperman] #1191135
03/05/12 11:37 AM
03/05/12 11:37 AM
Thanks again. Now I have to find one.
I also have to check the motor.
I found a thread where you explained how to test a 3 speed motor.
1968 Coronet
1968 Charger
1966 A100 Pickup
1967 Barracuda
1970 Challenger
1972 Challenger
1973 Barracuda
2021 Ram 2500
