Big Block Oil Pump Size? #1191086
03/04/12 05:03 PM
03/04/12 05:03 PM
Santa Cruz, Ca
4woody Offline OP
4woody  Offline OP
Santa Cruz, Ca
I'm doing an engine swap and trying to make a 383 fit in my '38 Chrysler frame.
Is there a size (depth) difference between an HV Oil pump and a std pump?
I've got an HV, but don't have a std one to measure.
Tia
Re: Big Block Oil Pump Size? [Re: 4woody] #1191087
03/04/12 05:10 PM
03/04/12 05:10 PM
Kirkland, Washington
Pacnorthcuda Offline
Yes, the HV units are "taller" thats how they work. I think its something like .300"
Re: Big Block Oil Pump Size? [Re: Pacnorthcuda] #1191088
03/04/12 05:40 PM
03/04/12 05:40 PM
Santa Cruz, Ca
4woody Offline OP
4woody  Offline OP
Santa Cruz, Ca
I figured they were taller- I just didn't know how much. How sure are we about the .3" difference?
Could anyone -PLEASE- measure one for me??
Re: Big Block Oil Pump Size? [Re: 4woody] #1191089
03/04/12 06:41 PM
03/04/12 06:41 PM
Prospect, PA
BSB67 Offline
BSB67  Offline
Prospect, PA
Rotor is .94 on the std.
Re: Big Block Oil Pump Size? [Re: BSB67] #1191090
03/04/12 09:09 PM
03/04/12 09:09 PM
Out in Left Field, NY
bobs66440 Offline
bobs66440  Offline
I measured mine.
4-3/4" from mounting surface to top of round part where filter is (overall height)
2-3/4" from mounting surface to top of round part on body
2" from mounting surface to top of mounting bolts
In other words, it's 1/4 - 3/8" shorter
Re: Big Block Oil Pump Size? [Re: bobs66440] #1191091
03/05/12 01:12 AM
03/05/12 01:12 AM
Santa Cruz, Ca
4woody Offline OP
4woody  Offline OP
Santa Cruz, Ca
Wow-
That .3" guess was pretty close!
Thanks for measuring.
Re: Big Block Oil Pump Size? [Re: 4woody] #1191092
03/05/12 09:48 PM
03/05/12 09:48 PM
Prospect, PA
BSB67 Offline
BSB67  Offline
Prospect, PA
Std. is .945" and the HV is 1.187". Difference is about .242", plus or minus a couple.
