Page 3 of 4 1 2 3 4
Re: 400 BB Mopar budget dyno test [Re: Brian Hafliger] #1190614
03/06/12 06:47 PM
03/06/12 06:47 PM
Baltimore/Denver
64Post Offline
64Post  Offline
Baltimore/Denver
Now try it with a 4.15 crank and 11.0 comp...
Then add OOTB Eddys and a little more cam...
Then add MCH Eddys and a little more cam...
Then add maybe a Victor jr. and 2" headers...
thanks
Re: 400 BB Mopar budget dyno test [Re: 64Post] #1190615
03/06/12 09:09 PM
03/06/12 09:09 PM
oberlin, Ohio
Rapid340 Offline
Rapid340  Offline
oberlin, Ohio
I often have more fun doing a budget build than a build where cost isnt much of an issue.
Thanks for sharing the results.
1971 Factory Appearing Duster 340 11.000 @ 122 mph
Re: 400 BB Mopar budget dyno test [Re: Brian Hafliger] #1190616
03/07/12 04:33 AM
03/07/12 04:33 AM
AUSTRALIA
CLEVO351 Offline
CLEVO351  Offline
AUSTRALIA
Brian
It started getting a bit rich in the top end looking at the A/F and BSFC, there could of been a little more power there.
Re: 400 BB Mopar budget dyno test [Re: CLEVO351] #1190617
03/07/12 05:01 AM
03/07/12 05:01 AM
SoCal
Brian Hafliger Offline OP
SoCal
Brian
I think because of the non adjustable rockers, and having about .050 depression on the lifter plunger, we were seeing some lifter pump up causing erratic #'s.
For sure, with different rockers power could go up a fair amount. I thought the TQ curve was pretty good as well as the wide powerband for such a short stroke.
Brian Hafliger
Re: 400 BB Mopar budget dyno test [Re: Brian Hafliger] #1190618
03/07/12 09:12 AM
03/07/12 09:12 AM
IL
E
EchoSixMike Offline
EchoSixMike  Offline
E
IL
So, given a choice, adding some roller rockers would BE the 1st money you'd spend additionally? The HS Mancini's, for example? S/F....Ken M
edited to make sense
Re: 400 BB Mopar budget dyno test [Re: EchoSixMike] #1190619
03/07/12 12:02 PM
03/07/12 12:02 PM
U.S.S.A.
JohnRR Online rolleyes
JohnRR  Online Rolleyes
U.S.S.A.
So, given a choice, adding some roller rockers would the 1st money you'd spend additionally? The HS Mancini's, for example? S/F....Ken M
I would ask that question as adding an adjustable rocker or the correct length pushrods.
Re: 400 BB Mopar budget dyno test [Re: JohnRR] #1190620
03/07/12 12:24 PM
03/07/12 12:24 PM
gregsdart Offline
gregsdart  Offline
Being a budget build, what about some cast steel rockers? Cheaper, will work with a lot of cams, including mild rollers.
I have often considered a 400 stock stroke motor to have some advantages as a bracket motor as well as a cheap street combo with good potential. Lower torque off the line would really make consistency easier to achieve. A juice cam and pump gas equals cheap, many runs before maintenance racing!
Re: 400 BB Mopar budget dyno test [Re: JohnRR] #1190621
03/07/12 12:36 PM
03/07/12 12:36 PM
Sk. Canada
RemCharger Offline
RemCharger  Offline
Sk. Canada
My cure was comp Pro magnum lifters and adjustable pushrods. 6500 rpm reliable.(xe 284)
Re: 400 BB Mopar budget dyno test [Re: 64Post] #1190622
03/07/12 12:40 PM
03/07/12 12:40 PM
Sk. Canada
RemCharger Offline
RemCharger  Offline
Sk. Canada
thanks
My take would be
same crank and 13:1 pistons
then add 325 440-1s
then add 275/282 roller cam
then add 1050 pro sys dommy
then add another one.
Re: 400 BB Mopar budget dyno test [Re: RemCharger] #1190623
03/07/12 01:20 PM
03/07/12 01:20 PM
SoCal
SoCal
I'd like to see what a MW style head and roller cam/compression would do too....hmmmmm.
Brian Hafliger
Re: 400 BB Mopar budget dyno test [Re: RemCharger] #1190624
03/07/12 01:38 PM
03/07/12 01:38 PM
Baltimore/Denver
64Post Offline
64Post  Offline
Baltimore/Denver
thanks
My take would be
then add 325 440-1s
I was looking for a budget oriented strong street/strip combo that makes about 650 hp in a stock block. Plus, I have a 4 speed tranny, so I'm kind of limited.
I'm not rich like you guys with your roller cams and high-dollar heads...
Then, when Brian is done building and testing it I can buy it from him at a discount.
Re: 400 BB Mopar budget dyno test [Re: Brian Hafliger] #1190625
03/07/12 01:53 PM
03/07/12 01:53 PM
Northern Indiana
Dunnuck Racing Offline
Northern Indiana
Brian
I agree,the heavy stock sized valves tend to keep a hydraulic cam from working well at higher rpm's unless everything is just right.
As for leaning it out on the top end for more power,that does not always work out so well. I have spent a lot of time getting a flat A/F across the board before just to find that the engine wanted the extra fuel. It depends on the fuel used and how the engine combo is working with it.
I have also tried it at the track to see how the results from the dyno pan out. I have had to go back to the richer settings on the top end to get the mph back up. Many variables come into play!
Keith
Re: 400 BB Mopar budget dyno test [Re: 64Post] #1190626
03/07/12 02:52 PM
03/07/12 02:52 PM
Sk. Canada
RemCharger Offline
RemCharger  Offline
Sk. Canada
thanks
My take would be
then add 325 440-1s
Quit wasting your money on 500" big blocks and you can buy good heads too!
Re: 400 BB Mopar budget dyno test [Re: RemCharger] #1190627
03/07/12 02:58 PM
03/07/12 02:58 PM
SoCal
SoCal
thanks
My take would be
then add 325 440-1s
Ha ha! You guys crack me up!!
650HP and budget should not be in the same sentence IMO.
Yeah, the 400 is for sale...even if it's not 650HP!
Brian Hafliger
Re: 400 BB Mopar budget dyno test [Re: CLEVO351] #1190628
03/07/12 03:23 PM
03/07/12 03:23 PM
Overpriced Housing Central
RobX4406 Offline
RobX4406  Offline
Brian
Our pump swill may have 20-25% ethanol in it.
Re: 400 BB Mopar budget dyno test [Re: RemCharger] #1190629
03/07/12 04:15 PM
03/07/12 04:15 PM
Baltimore/Denver
64Post Offline
64Post  Offline
Baltimore/Denver
thanks
My take would be
then add 325 440-1s
Re: 400 BB Mopar budget dyno test [Re: Brian Hafliger] #1190630
03/07/12 08:19 PM
03/07/12 08:19 PM
gregsdart Offline
gregsdart  Offline
thanks
My take would be
then add 325 440-1s
Brian, how do you think this combo would stack up for cheap HP?
406 cubes, hogged out iron heads using the old MP templates, flat tappet mm305 cam, tunnelram with two Thermoquads (by Dave, AKA Quickd100). Won't get much cheaper than that for an all out hp "cheap" build! If the shortblock is built right and the heads flow about 270, should be able to make 600+ anyway.
Re: 400 BB Mopar budget dyno test [Re: gregsdart] #1190631
03/07/12 10:33 PM
03/07/12 10:33 PM
Between a rock & a hard place
cudadoug Offline
cudadoug  Offline
thanks
My take would be
then add 325 440-1s
I don't know about dyno numbers, but I can chime in with one of my 383 experiences...low dollars and NO SENSE, lemme tell ya! Using 100% used parts, except for rings, bearings, and oil I slapped this together:
*Domed TRW slugs, didn't measure actual CR, but it was zero decked with a measured 80 cc 452 head.
*Resized stock rods with good bolts.
*Those 452 heads went 250-ish on our bench.
*MP 590 cam
*MP single plane and 3310 Holley
*8" converter
*4.89 gears w/a 29.5 slick
*Weight 3420 E-Body
*10.90 @ 122 in real good air
Same motor, heads improved by 15 peak CFM...
*Ultradyne .613/276 @ .050 cam
*Adaptor and 1050 Dominator
*A body at 3180
10.62 @ 125 in Sacto summer air
Then added a TR and twin 1406 (?) Eddy's, more tweaking and got it to go 10.43 @ 126 best. Yes, most all said "it just had" to be a low deck stroker. Those little 383/400/406 wedgies CAN run!
Re: 400 BB Mopar budget dyno test [Re: cudadoug] #1190632
03/08/12 12:00 AM
03/08/12 12:00 AM
Baltimore/Denver
64Post Offline
64Post  Offline
Baltimore/Denver
The point I was trying to get at is a $3500 after market block, a $2000 Callies crank, $1200 Aluminum rods, $4000+ heads, isn't required for 650 hp. Sure, you can dump $15K+++ in the project if you want, but it really isn't needed.
Re: 400 BB Mopar budget dyno test [Re: 64Post] #1190633
03/08/12 12:57 AM
03/08/12 12:57 AM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
That is definetly true. But I dont think I would want to push a stock block much more the 650 hp. I would say my 493 is pushing about 600 to 610 hp and so far no problems at all with my stock block. Ron
Page 3 of 4 1 2 3 4
