Re: K-frame project
[Re: autoxcuda]
#1190119
03/03/12 01:25 AM
03/03/12 01:25 AM
Posts: 4,302 Nebraska
72Swinger
Nebraska
Why the big rectangle box instead of just a tube that the bar fits in? Will definitely be effective no matter how you configure it.
Mopar to the bone!!!
Re: K-frame project
[Re: Jim_Lusk]
#1190121
03/03/12 02:13 AM
03/03/12 02:13 AM
Posts: 186 Middleton, ID
curleysracecars
Middleton, ID
Glad you're making it work. This is what I was referring to in the "sway bar" thread that is going. I also wonder why the square/rectangle tube instead of just the round tube going through the K? You could weld a round tube in the K, and then your actual anti-roll bar would be a precise fit through the welded tube...allowing rotational movement, but limiting any distortion. Just a thought...keep posting pictures.
Kyle Curley
Re: K-frame project
[Re: PHJ426]
#1190125
03/03/12 04:17 PM
03/03/12 04:17 PM
Posts: 30,998 Oregon
AndyF
Andy, any pictures of the other side of the K frame.
Are the triangulated pieces added to the K frame permanent or are they there to act like a jig to keep it square during construction?
I always like reading about your projects keep the info and pictures coming.
Do you cover K frame mods like this in the B body book and by the way is it available for purchase now?
The braces are the jig to keep things square during fab. They'll be cut off once the K frame is all welded up.
My B-body book is available in the book section of Moparts. I do cover a lot of suspension, brake, wheels, chassis, etc. topics in it.
http://www.moparts.org/moparts/books/index.html
