I want to know how they got to 10:1+ with "cast flat top pistons" and used 906 heads?
Assuming the "Cast piston" is a Keith Black #162 with a 1.908" compression height and 5cc valve reliefs as a starting point. Because most other "Cast" pistons have no valve reliefs, and sit further down the bore, like the SP-366 that has a 1.848" compression height.
Anyhow, with the KB162 piston, and a "stock" deck height of 9.980", 6.380" rods, and 3.380" stroke, the piston would be 0.024" below the deck.
With a 9.9cc Fel-pro head gasket, the "906" chamber volume would have to be 72cc which is pretty small for a 906 head.
If the blocked was decked 0.024" to "zero deck" the pistons, and they used a 0.020 shim gasket, the head maximum head volume would need to be less than 78cc to get 10:1 compression, and 78cc is still pretty small chamber for a 906 head.
Also, what does "the 906 ports were cleaned up, but not extensively ported" mean? Why not flow the heads and give us the flow numbers?
Then they chose a mild "solid lifter" cam. I guess so they can mess with the valve lash to tune the power curve? Then a victor single plane intake? Why not the RPM intake?
Then the dyno test starts at 3,500 RPM? I guess they think we all drive around with 5.13:1 gears?
Just another reason I let my subscription expire. I'm sure the same article will be in Hot Rod or Car Craft soon after it is published in Mopar Muscle.
