Re: Pull the engine and trans out together or seperate?. SB
[Re: Fat_Mike]
#1188998
03/01/12 02:33 PM
03/01/12 02:33 PM
Posts: 7,274 s.w.fl
bonefish
s.w.fl
get the rear of the car up as high as you saftly can,it makes it alot easier.and get one of these.worth its weight in gold.
[Re: Mr.Yuck]
#1188999
03/01/12 11:52 PM
03/01/12 11:52 PM
Posts: 958 eastern, pa.
cudabitten
eastern, pa.
easier coming out seperate, easier going in together. Pick your poison. I'd say pull both, that way you can service the trans while your motor is out getting work.
This was my idea as well. The transmission seamed ok when I parked the car four years ago. I think just a fluid/screen change and belt adjustment. Its been a while since I've done this stuff.
To the other posters, I just picked up a hoist a few hours ago, and it came with one of thoses levelers. I hadn't even heard of this piece before, so thank you for passing the knowledge. I already have a friend lined up to help with the removal. Thanks for all the advice, I think were gonna try to remove both together. I'm going to post again when I'm ready for some ideas for holding the engine and trans while seperating. Wood blocks and tires will probably be fine though. Thanks, Chris.
[Re: bonefish]
#1189001
03/02/12 09:52 AM
03/02/12 09:52 AM
Posts: 1,511 AZ
Mike P
AZ
Those levelers work great, but just a hint when you use it, especially when reinstalling the motor. Use the next to the last pair of intake manifold bolt holes for the rear chain, not the most rear ones. You have no idea how you get when you finally have the whole mess almost back into position only to find out you have to pull everything back out because the chain is hitting the firewall and you can't go back far enough.
1957 Plymouth (Hemi, Dual Quads, A833 4 Speed 9 1/4 w 4.10) Sold 1937 Dodge Pickup (Hemi, 6X2 intake, 46RH, Dana 60 w 4.56) Sold 1968 Plymouth Valiant 2dr sedan (354 HEMI, 46RH w/4.30 gears)
[Re: bonefish]
#1189002
03/02/12 11:00 AM
03/02/12 11:00 AM
cudabitten
eastern, pa.
leave the starter hooked up pull the pan and you can take he tq bolts out with a impact wrench,makes life MUCH easier.
Ok, your talking to an amateur here... The oil pan right? What are TQ bolts? Dont laugh at me.
Also Mike, thanks for the tip about the hoist placement.
[Re: bonefish]
#1189005
03/02/12 12:40 PM
03/02/12 12:40 PM
Posts: 3,719 Space Station #5
471Magnum
Space Station #5
A leveler is a must if pulling together, but if they both have to come out, that's the way to go.
Check Harbor Freight for levelers. I think I paid $30 for mine 5-10 years ago and it works really well.
Jack the rear of the car way up to minimize the tilt required to clear the rad support. Definitely a two man job.
-Jim
I can fix it... my old man is a television repairman. He's got the ultimate set of tools... I can fix it.
Currently Mopar-less
[Re: bonefish]
#1189006
03/02/12 01:07 PM
03/02/12 01:07 PM
Posts: 1,301 Edgartown, MA/ Greene, ME
CharlieB
best investment even for a single in/out project
[Re: 471Magnum]
#1189007
03/02/12 01:08 PM
03/02/12 01:08 PM
Posts: 3,957 West Coast, CA
Troy
West Coast, CA
.......jack the back end of the car as high up as you can get it and pull the two together. You will have no problem at all.....
....there is nothing like driving my 1968 Hemi Dart around town and having people looking at you like you're nuts!!
[Re: cudabitten]
#1189008
03/02/12 01:19 PM
03/02/12 01:19 PM
Challenger 1
Cincinnati, Ohio
Definitly take them out togeather. Homemade by me, took a piece of 1/2" cold rolled steel and heated it up and wrapped it around a piece of pipe and then welded the ends. Been using it for 30 years dozen of times, best part is was free.
[Re: Bull1tt]
#1189012
03/03/12 01:07 PM
03/03/12 01:07 PM
Posts: 1,606 Pgh, PA
Bull1tt
Pgh, PA
