wiped a lobe... expensive lesson...update
#1188044
02/29/12 09:47 AM
02/29/12 09:47 AM
Posts: 3,719 Space Station #5
471Magnum
Space Station #5
This stroker motor of mine has had its share of issues. Most recently, I've noticed some increasing tappet noise. I decide to remove the intake for inspection. Found the #5 intake lifter to be partially digested. This motor probably has less than 2000 miles on it. I've had the intake off several time along the way and each time inspected the lifters. This is a recent development. Most recently, I replaced/upgraded the heads. Again, I noticed no cam or lifter wear while I had it apart. One thing I neglected to do after changing the oil this last time was to pour in the Comp Cams additive I've been using. In less that 200 miles, this is the result. For the record, the cam is (was) a Comp Cams XE274HL. Nothing too crazy. Valve springs are beehives from IMM. Not sure of the pressures, but probably not much more than the double springs I ran on the old heads. Running iron adjustable rockers. Right now I'm going with the theory that its an oil failure, with maybe a chinese lifter factor mixed in. I haven't decided on my replacement plan yet. If I stick with Comp Cams, I'll probably step up a bit to a XE275HL. As far as lifters go, I'm not sure. One thing for certain, I'm about to pay my "stupid tax".
-Jim
I can fix it... my old man is a television repairman. He's got the ultimate set of tools... I can fix it.
Currently Mopar-less
Re: wiped a lobe... expensive lesson
[Re: 471Magnum]
#1188046
02/29/12 10:02 AM
02/29/12 10:02 AM
Posts: 2,093 oberlin, Ohio
Rapid340
oberlin, Ohio
Sorry to hear, what oil did you use?
Also, it is a really good habit to never remove more than one lifter at a time when inspecting them or transfering to a lifter box for storage. I'm not saying you did anything wrong but I know if I am not careful all I need to do is misplace one to have issues.
1971 Factory Appearing Duster 340 11.000 @ 122 mph
[Re: Challenger 1]
#1188047
02/29/12 10:08 AM
02/29/12 10:08 AM
471Magnum
Space Station #5
I checked the pre-load a couple of times prior to this. That cam as always been a bit noisy. It's certainly possible that could be the cause. I'll definitely have the opportunity to set it with the intake off this next time.
It's also probably worth mentioning that the #5 cylinder also seems to have an oil consumption problem. The plug fouled-up with oil. I did a compression check to find that cylinder 20 psi lower than the others. That could be attributable to the reduced intake lift. Before I found the wiped lobe, I was leaning towards re-ringing that cylinder.
-Jim
[Re: 471Magnum]
#1188048
02/29/12 10:15 AM
02/29/12 10:15 AM
Posts: 5,746 Ontario, Canada
Dodgem
Ontario, Canada
Get good lifters and make sure you do not preload to much. Hughes offers Cryogenic treatment for the lifters and probably the cams too. pay me now or pay me later. My be time to step up to a hydraulic roller. For sure always use a zinc additive!!!
[Re: MLR426]
#1188051
02/29/12 11:50 AM
02/29/12 11:50 AM
A57_RT
Parts Problem
Parts Problem
With it that far gone, didnt it show signs of issues long before this point??? Ive run old junkers for years that ticked, knocked and the worst lifter I ever saw was a pushed in bottom, thats ugly.... Good luck on the fix though Its got to be bad parts these days, luck of the draw??? I say this simply because luckly ive not had this happpen ever, just a good stash of old stp and std breakin like we all do. Im still trying to grasp the concept of metal on metal when most dont consider a cam a wear item.
[Re: A57_RT ]
#1188053
02/29/12 01:17 PM
02/29/12 01:17 PM
471Magnum
Space Station #5
I ran this motor a bunch before this. Had a saga with the heads leaking through the guides that took a long time to resolve, and probably masked and distracted me from this issue. Finally installed the RHS heads to take care of that.
That being said, I inspected the lifters on several occasions prior when I had the motor torn down for the head issues. No wear was noted.
It's always have had a lot of lifter noise. Tweaked the preload in an attempt to quiet it down some to no avail. It's possible that I over did it.
I used plenty of break in lube. The Comp Cams additive was at oil changes... but not this last one.
Biggest concern now is lifter trash and potential bearing damage.
As far as what cam and lifter package goes in next, I'm not sure. It'll will likely be a similar grind as I really liked the performance. I'll probably be talking with Hughes this weekend in Indy.
-Jim
[Re: 471Magnum]
#1188054
02/29/12 01:35 PM
02/29/12 01:35 PM
Posts: 75,066 U.S.S.A.
JohnRR
U.S.S.A.
There is no potential damage, it's a definite with that much worn off that lifter , I'm sure the cam looks as bad.
Metal chips on the piston skirts in the vicinity of that lobe and the oil pump will be scared because it sees unfiltered oil.
[Re: JohnRR]
#1188055
02/29/12 01:40 PM
02/29/12 01:40 PM
Challenger 1
Cincinnati, Ohio
Yup it's gonna be neccessary to replace all bearings, maybe rings and more. Every inch and passage of the block, crank, rods and pistons will need to be cleaned.
[Re: 471Magnum]
#1188056
02/29/12 02:54 PM
02/29/12 02:54 PM
471Magnum
Space Station #5
I'll start tearing into it further tonight. We'll see what I find when I pull a few caps.
The cam lobe is definitely damaged. I haven't turned the motor over to inspect the entire lobe, but yeah, the cam is toast, no doubt.
I'm not counting on getting lucky.
-Jim
[Re: Kern Dog]
#1188059
02/29/12 06:18 PM
02/29/12 06:18 PM
JohnRR
U.S.S.A.
These cams are a bit noisier than other types. I wasted 2 XE285s in my 493. I also figure that it was due to my ignorance about inadequate Zinc protection. I've since learned plenty on the subject, but there is always room for improvement. Comp now offers the "Pro Plasma" treatment. Its a sort of surface hardening that along with proper oil, should last a long time. I'm thinking of switching back to that 285 since I liked the performance ans streetability of it. Sorry for your troubles. Broken parts are a hard lesson to learn, huh?
is that pro plasma the same as the nitride they offer to the tune of $150 EXTRA ???
[Re: Kern Dog]
#1188060
02/29/12 09:19 PM
02/29/12 09:19 PM
471Magnum
Space Station #5
I don't necessarily think it's the cam that's noisy, but the lifters that come with the kits. I'll be ordering a set of Topline Hylifts for the next cam.
I'm in the process of pulling the pan now. No obvious junk found when I drained the oil, but I didn't expect to find anything. Trying to bust the drag link from the idler arm. Got to feeling weak swinging the mini sledge. Decided I'd better take a dinner break. LOL
-Jim
[Re: 471Magnum]
#1188061
02/29/12 10:35 PM
02/29/12 10:35 PM
Posts: 489 NE
bigtail
NE
I second the use of Hyd rollers. You would have been bucks and headaches ahead at this point. Be aware, Comp Cams had had catastruaphic failures with their roller hyd lifters. Maybe time to change to another brand. Do a google search.
This page is made up completely of recycled electrons.
[Re: 471Magnum]
#1188062
02/29/12 11:52 PM
02/29/12 11:52 PM
JohnRR
U.S.S.A.
It's the cam , XE have fast ramps and the valves tend to slam shut.
