Re: MORE sway bar questions.
[Re: Kern Dog]
#1186230
02/26/12 05:30 AM
02/26/12 05:30 AM
1_WILD_RT
Management Trainee
Management Trainee
Today? Who Knows?
A 1.375 front bar won't fit through the K member, at least not if the car is equipped with the skid plate... So you'd have to change the mounting...
[Re: Kern Dog]
#1186232
02/26/12 05:48 AM
02/26/12 05:48 AM
1_WILD_RT
Management Trainee
Management Trainee
Today? Who Knows?
Yeah, but I'm referring to it making the turn to pass through, once it's in place I'm sure there is room but passing a 1.25 bar through you need to get the angle just right, I don't know if a 1.375 would make the bend even without a skid plate...
[Re: Kern Dog]
#1186235
02/26/12 01:14 PM
02/26/12 01:14 PM
Posts: 5,394 Pikes Peak Country
TC@HP2
Pikes Peak Country
How much larger in diameter does a tubular bar have to be to have equal strenth of a solid bar? Does anyone know of a company that offers a 1 3/8" solid front bar? Thanks, Greg
I posted a link to a calculator in your "all thing being equal" post. You can use that to look at the differences in solid vs tubular bars. The big variable in tubular bars is the wall thickness.
If you really want to get in to more detailed bar tuning than what is simply available off the shelf, you may need to look at going to with a splined tube with modular arms. You can find these at http://www.1speedway.com/ or search around for used nascar parts warehouses.
As far as opening up the pass though slot, if you need a larger opening, you just need to stretch them a bit or cut and reweld the adjoining tab.
[Re: ThermoQuad]
#1186238
02/27/12 02:36 AM
02/27/12 02:36 AM
Posts: 18,493 Granite Bay CA
Kern Dog
Striving for excellence
Granite Bay CA
What bushing material are you using? POLY Whose sway bar? ADDCO How tight are the end link bushings. They should be tight. THEY ARE
The T bars are 1", the front bar is also Addco with poly bushings. The reinforced K is in the works.
[Re: rabid scott]
#1186244
02/29/12 02:56 PM
02/29/12 02:56 PM
Posts: 22,696 Bitopia
jcc
Bitopia
Sorry is this post isn't more congenial, my computer crashed and I lost my first in depth reply. I'll try again. I know there are well respected members here who fervently promote K member welding reinforcement. I am nor suggesting one bit that this causes any harm. I am having a tough time getting on this bandwagon. Hey somebody has to ask the tough questions. So for years we have read seen 1/4's cut/notch/etc their factory k members to gain clearance for oil pans/etc. One would think that if simple welding to a k gave noticeable positive results, one would think that significant cutting to a k would at least inspire negative comments in handling. I know we are not comparing apples to apples, but i have never heard a drag racer say his car handles worse after chopping up his K member. Additionally, there are a number of after market k members, that IMO are much less stiff then the OEM K member. The after markets TB/K's with tubing are lighter and provide bragging rights, but I have yet to see one stiffer then OEM. Do we hear a degrading in handing with them? We are not talking Alterk since with coils the loading is much different. Another beauty of the mopar K, is the heaviest object in the car is connected directly over the load path to the lca sprung suspension point, a very stiff design. My question here is not with the results noticed, its the analysis of what actually caused the results. I will/have welded my K's when the situation presents itself, since I weld and the only real downside is dirty welds, and warpage from rushing the weld. I don't know what forces the additional welding is resisting, and that a better more effective solution might be a "shock tower" brace. I have never heard of the OEM K member spot welds failing from long term use, which kinda indicates to me they are not highly stressed in the first place, and addition welding may not offer much. I believe any weld that is flexed, will over time, eventually start to fail. It might be most useful if one looks at the above opinion in its entirety, rather then focus on one specific point.
[Re: jcc]
#1186245
02/29/12 03:33 PM
02/29/12 03:33 PM
Kern Dog
Granite Bay CA
I'll agree to a point that I thought that the perimeter spotwelds appear top be adequate. Often times I defer to those that seem to have more experience, then occasionally second, and THIRD guess the decision. One thing that makes total sense and I can't WAIT to prove it to my self is the benefit of the STEERING BOX MOUNT GUSSETS. I wrote in all caps to make sure it wasn't missed. If Firm Feel thinks that it is important, I'd tend to follow their suggestion. It was an easy decision for me because I had a spare K member for my car. Its far easier to work on these things on a TABLE than under the car with the engine still in there. For me, I just looked over the steering box area and filled in all gaps with .125 wall steel plate. Pretty simple really. I also made sure to NOT encroach on any area that could interfere with the mounting of the steering chuck itself. I test fitted a PS chuck to be certain. Then I welded washers around the LCA pivot holes. I have personally seen these ripped out on cars that ran too long on bad LCA bushings or others that were involved in a collision. Imagine what them Duke boys did when they jumped the river at Seminole Canyon! Finally I added similar washers over the strut rod hole. This area I also have seen pushed in from collision damage. All in all the modifications that I did cost me about $10 plus whever Argon and MIG wire I used. Oh yeah... the 220V electricity, the sawzall blades to cut materials and the grinder discs to hide my"less than stellar" welds. Lets call it $20. My opinion of this mod? It MAY provide more precise steering response since I am running some pretty wide tires. Less deflection when I encounter a bump with one wheel too. The washers welded on? If it saves me from a damaged K member, thats great. All the perimeter welds may have been for nothing, but the other areas should provide some benefits. Opinions may vary, of that I'm certain.
Oh, I forgot to touch on this point: Drag racers that do not complain about handling deficiencies? I would think that the straight line guys would be more concerned with how well the cars track at 120 mph on a smooth surface rather than take their cars on bumpy, twisty roads with 195-75-15 front drag tires. The skinny tires give up traction before the flimsy steering mounts see much stress. They may have never noticed any K member flex at all.
