so who wins this one?
#1186133
02/25/12 10:56 PM
02/25/12 10:56 PM
Posts: 4,525 Daisyland USA
jnkgal
Daisyland USA
One car has issues at the light at the start the other one does a wheel stand and goes swirving and hitting the wall but crosses the finish line first but backwards.. then comes the other one bearly able to go down the track later crossing the line ![](/ubbthreads/images/graemlins/shruggy.gif)
"A goal without a plan is just a wish."
Re: so who wins this one?
[Re: jnkgal]
#1186142
02/26/12 01:28 AM
02/26/12 01:28 AM
Posts: 43,305 Bend,OR USA
Cab_Burge
I couldn't get the video to work, I'm not a Tweeter ![](/ubbthreads/images/graemlins/shruggy.gif) NHRA rules have always had the first or worst rules in competion(eliminations), that rule says and means that the first offender, IE redlight, or the worst offender, cross the centerline or hit the guard rail goes out. I've seen a racer, me, reinstituted whan a racer was below the minimum weight at the scales, Same thing if the other racer crosses the center line when you redlight, the redlight is first but crossing the centerline is worst, so the redlighter gets back in ![](/ubbthreads/images/graemlins/confused.gif) ,simple huh ![](/ubbthreads/images/graemlins/whistling.gif)
[Re: Cab_Burge]
#1186144
02/26/12 10:29 AM
02/26/12 10:29 AM
Posts: 2,131 New Lenox IL
cudadon
New Lenox IL
I couldn't get the video to work, I'm not a Tweeter NHRA rules have always had the first or worst rules in competion(eliminations), that rule says and means that the first offender, IE redlight, or the worst offender, cross the centerline or hit the guard rail goes out. I've seen a racer, me, reinstituted whan a racer was below the minimum weight at the scales, Same thing if the other racer crosses the center line when you redlight, the redlight is first but crossing the centerline is worst, so the redlighter gets back in ,simple huh
Yes Cab, simple. ![](/ubbthreads/images/graemlins/thumbs.gif) Don
