Best way to remove vinyl top goo... er.... glue. #1185028
02/23/12 09:20 PM
02/23/12 09:20 PM
Bowling Green KY / Nashville, ...
300by500 Offline OP
300by500  Offline OP
The original paint is in decent shape, but there was rust under the vinyl top on the Dart - so I am going to replace it. I got all of the trim off without dinging or bending it thanks to advice found here on Moparts!
After removing the vinyl, there's a LOT of glue there. What's the best way to remove it?
Re: Best way to remove vinyl top goo... er.... glue. [Re: 300by500] #1185029
02/23/12 09:21 PM
02/23/12 09:21 PM
Kirkland, Washington
Pacnorthcuda Offline
DA Sander. Works great.
Re: Best way to remove vinyl top goo... er.... glue. [Re: 300by500] #1185030
02/23/12 09:34 PM
02/23/12 09:34 PM
Ohio
JT01 Offline
JT01  Offline
Ohio
Take some Kereosene and wet it down let it soak for a minute then put a little more on and take a razor blade and it will come right off
