Re: carb boiling [Re: Challenger 1] #1184919
02/24/12 12:43 PM
02/24/12 12:43 PM
Nampa, ID
None2Slow Offline
None2Slow  Offline
Nampa, ID
How accurate is your fuel pressure gauge? If you can make it home by turning the pump off and on, then I would think the problem is with the fuel pressure. Maybe turn it down even lower then an indicated 5psi and see if it makes a difference.
Re: carb boiling [Re: None2Slow] #1184920
02/24/12 01:58 PM
02/24/12 01:58 PM
s.w.fl
bonefish Offline OP
bonefish  Offline OP
s.w.fl
i put a brand new guage on it and a new reg.so now i have a spare reg and guage.its a 1050 dom.on my other cars i run 7 1/2 to 8 lbs and they dont over flow.im gunna try turnin it down some more and see if i go lean at wot.i may try to richin it as a last resort my LM1 says its not lean.
Re: carb boiling [Re: bonefish] #1184921
02/24/12 03:38 PM
02/24/12 03:38 PM
MD-USA
Dodgeguy101 Offline
Dodgeguy101  Offline
MD-USA
Have you tried different gas in it? Maybe you got a bad batch of something???
Re: carb boiling [Re: Dodgeguy101] #1184922
02/24/12 03:52 PM
02/24/12 03:52 PM
s.w.fl
bonefish Offline OP
bonefish  Offline OP
s.w.fl
im on my 3rd tank,i drive it alot.20mi.AT A TIME
