Re: Which quench and comperssion?
[Re: moparniac]
#1184198
02/23/12 10:49 AM
02/23/12 10:49 AM
Posts: 3,698 NE Oklahoma
Von
NE Oklahoma
what were your timing events.
Glad you reminded me!!
.050 Open Close
Int 24 BTDC 56 ABDC Exh 63 BBDC 23 ATDC
72 RR, Pump gas 440, 452s, 3800 lbs, Corked, ET Radials,. 11.33@117.72.
Same car, bone stock 346s, 9.5 comp, baby solid. 12.24@110.
[Re: moparniac]
#1184200
02/23/12 11:34 AM
02/23/12 11:34 AM
Von
NE Oklahoma
My custom roller intake valve closing is 73
What is your duration at .050?
[Re: Von]
#1184201
02/23/12 12:24 PM
02/23/12 12:24 PM
Posts: 155 Tulsa oklahoma USA
2734bbl
Tulsa oklahoma USA
I dont like any of the Compression/quench options for the statement, "It has to run on 91 octane on the street" Whats up with that? Thats the best pump gas you have in Oklahoma? A state right next to Texas, the bigf oil state.
I havent seen 93 in my part of OK in along time. 10 years at least. It is super lame....Quote:
Aint that a sad truth...... 93 starts at the Texas border.
Best I've found is 92 at the Flying J truck stop in Tulsa.
Re: Which quench and compression?
[Re: BradH]
#1184203
02/23/12 09:03 PM
02/23/12 09:03 PM
Von
NE Oklahoma
What gaskets are you factoring into your equations? Are you running the #s for different bore diameters as well as compressed thicknesses?
Oh, in case you're not using it, the CR calculator on Diamond Pistons' web site is perfect for running all these types of calc "What if..." scenarios. [/quote
.039 fel pro .045 rol .050 fel pro .060 cometic
Yes, Ive factored the different bore sizes in...
Myself, I like the compression calc on Stan Weiss' website. I'll check out the diamond calc.
