Can This Cam be Saved???
#1184118
02/22/12 05:59 PM
02/22/12 05:59 PM
Posts: 352 Arizona
69rrgrabber
Arizona
Just bought a new purple cam from a member and don't think I can use it. It looks like it was rusted and then cleaned with a wire wheel. There are some small pits and I can feel that it is rough at some of the discolorations. I have always use new cams in the past and really don't want to risk this one with so much invested, but thought I would ask about it. Attached is a pic.
"It takes a Mopar to catch a Mopar!"
1969 Charger R/T 440
1969 Road Runner 383
1970 Cuda 440
Re: Can This Cam be Saved???
[Re: scratchnfotraction]
#1184120
02/22/12 06:10 PM
02/22/12 06:10 PM
Posts: 490 Boston Ma
Hamtramck
Boston Ma
Not worth the risk. Return it as its far from new in that condition.
69 roadrunner conv. 4spd B5/X9
[Re: Hamtramck]
#1184121
02/22/12 06:20 PM
02/22/12 06:20 PM
Posts: 352 Arizona
69rrgrabber
Arizona
My feelings too.
Thanks! CAC
1970 Cuda 440
[Re: 69rrgrabber]
#1184125
02/23/12 02:44 PM
02/23/12 02:44 PM
Posts: 75,089 A Banana Republic near you.
JohnRR
he told you that it was NEW ??? ... ... Nice .... I wouldn't run that , you could save it by having it reground , but by the time you pay for that it would have been cheaper to actually buy a new cam. Did you get a picture of that sent to you ?
[Re: JohnRR]
#1184126
02/23/12 05:08 PM
02/23/12 05:08 PM
dogdays
I've got a new in the box Olds W-30 cam from 1978 in the box and looks very similar. But I keep on putting the 455-in-a-65-Cutlass Supreme project farther and farther back on the burner. I still consider that cam new as it has never been in an engine. But I would have to say it had some surface rusting from sitting if I were trying to sell it. Some of the marks on cams like that are staining and you cannot feel them using the fingernail test. Bullet Cams has some very nice lobes and their hydraulic flat tappet regrind price is something like $60. Find their Chrysler lifter lobes at http://bulletcams.com/Masters/HClobes.htm . R.
[Re: 69rrgrabber]
#1184127
02/23/12 06:44 PM
02/23/12 06:44 PM
Posts: 5,875 communist bloc of new jersey
jamesc
you answered your own question...and no one should have sold that cam as new, personally i wouldn't even sell it as used.
[Re: BDW]
#1184129
02/23/12 10:39 PM
02/23/12 10:39 PM
Posts: 2,415 Connecticut
Ron_M
Connecticut
If I may ask a dumb question...
Could something like that be blasted with say crushed walnut shells to make it usable? maybe prior to or after the wirebrushing?
Common sense is a flower that does not grow in everybody's garden
[Re: radar]
#1184133
02/24/12 04:23 PM
02/24/12 04:23 PM
Posts: 6,098 Valencia, España
NachoRT74
Valencia, España
I had a similar problem on MP 474/280 cam because box got wet and I noticed 2 months later. Fortunatelly the big problems were just on front trace. I decided not to use it not just for that reason since definitelly it looks still useable. I went with Crower 282HDP because it looks a very similar cam but maybe more streeteable spceially with A/C due the 112 centerline and smaller intake duration at 0.050.
On the rusted area I just needed to get rid the rust filed edges, and it can be even helpfull somehow, storaging oil there
[Re: radar]
#1184134
02/24/12 05:47 PM
02/24/12 05:47 PM
dulcich
Aren't the faces of the lobes hardened? Is that a problem if he were to polish them with a fine grit paper? Just wondering sorry to offer more questions and no answers to the thread.
Back in the mid '80's I had a big block MP Hemi Grind rust in the box like that. I ended up sanding it with #400 then #600 wet/dry paper in the solvent tank, wrapping my hand with the paper around each lobe and turning the cam. I put it in a 383 and it worked fine; years later I sold the engine to a guy putting it in a Dart, and it is still running that cam now, nearly 30-years later.
Would I risk it today? Probably not, but back then money was tight and it might as well have been the last high performance big block cam on earth as far as I was concerned. -dulcich
