6.1 swap - proper exhaust size? #1183812
02/22/12 12:31 AM
02/22/12 12:31 AM
Michigan, USA
ramman5600 Offline OP
Michigan, USA
Doing a 6.1 swap into a B-body and wondered if a 2.5 inch or a 3" would be best? Currently going to run normally aspirated but may go supercharger in the future.
-C
Re: 6.1 swap - proper exhaust size? [Re: ramman5600] #1183813
02/22/12 04:38 AM
02/22/12 04:38 AM
808CUDA Offline
808CUDA  Offline
When I did that swap on my '71 Cuda I already had a 2.5" TTi exhaust with x pipe and it ran like scalded cat. That being said the SRT comes with 2.75" exhaust and I run 3" on my SRT. You'll be perfectly fine with 2.5" and avoid drone with that size.
Re: 6.1 swap - proper exhaust size? [Re: ramman5600] #1183814
02/22/12 08:52 AM
02/22/12 08:52 AM
the frozen wastes...
Pale_Roader Offline
Swears too much
Pale_Roader  Offline
Swears too much
A 440, even a stock-ish one, likes a good 3" system. A 6.1 will make more power than even most serious 440's. I'd think 3" would be the minimum, especially if the (usually conservative) factory spec's a 2.75" system.
Re: 6.1 swap - proper exhaust size? [Re: Pale_Roader] #1183815
02/22/12 09:50 PM
02/22/12 09:50 PM
Michigan, USA
Michigan, USA
The factory has Cats, which I am not sure how restrictive they are. So one says 2.5 is fine the other says go 3". Anyone run the 3" and do they have the drone issue?
-C
Re: 6.1 swap - proper exhaust size? [Re: ramman5600] #1183816
02/23/12 06:38 PM
02/23/12 06:38 PM
Michigan, USA
Michigan, USA
-C
Any other thoughts?
Re: 6.1 swap - proper exhaust size? [Re: ramman5600] #1183817
02/23/12 07:46 PM
02/23/12 07:46 PM
Iowa, US
oldsklharo Offline
oldsklharo  Offline
Iowa, US
For what it's worth........ I have a '66 Coronet with a heavily built 383 BB and I just put a new 3" stainless system on. I went from a 2" to a 3" with a cross over pipe and my car really liked it!
Seemed to have better response and a little more power.........
I am currently gathering parts to do a 5.7 swap and will go with my new 3"
Re: 6.1 swap - proper exhaust size? [Re: oldsklharo] #1183818
02/23/12 10:37 PM
02/23/12 10:37 PM
Tampa FL
hemibeep Offline
hemibeep  Offline
Tampa FL
mine is 2.5" from tti front to back. No drone. x pipe. More than enough flow, the motor is only 370 cu in.
Re: 6.1 swap - proper exhaust size? [Re: hemibeep] #1183819
02/24/12 12:45 AM
02/24/12 12:45 AM
Dayton, Ohio
W
wldtm Offline
wldtm  Offline
W
Dayton, Ohio
my 5.7 hemi in the bcuda has 3" TTI front to rear. it has a little more drone than I would like sometimes.
they are flowmasters though.
Interested in having you car wired? Drag car, street car, EFI swap? PM for details
Re: 6.1 swap - proper exhaust size? [Re: wldtm] #1183820
02/24/12 04:44 AM
02/24/12 04:44 AM
808CUDA Offline
808CUDA  Offline
As for cats killing power, my understanding is high flow cats are efficient. There is a late model Super Bee running a Procharger F1D on a stock displacement 6.1 running through full exhaust of course LT headers and clicking 9.2's through cats, so I don't think they are that restrictive. One thing is for sure, it is LOUDER without cats
Re: 6.1 swap - proper exhaust size? [Re: 808CUDA] #1183821
02/24/12 04:46 AM
02/24/12 04:46 AM
808CUDA Offline
808CUDA  Offline
Oh yeah, trust me, 2.5" is PLENTY! I'm not kidding you, my Cuda runs UNREAL fast with a "lowly" 2.5" exhaust
Re: 6.1 swap - proper exhaust size? [Re: 808CUDA] #1183822
02/24/12 04:14 PM
02/24/12 04:14 PM
sweden
1Fast340 Offline
1Fast340  Offline
sweden
just a note here,alot of people seem to think that exhuast size is all dependent on enginesize,this is not true,far from it.
sure engine size has a place in the equation but its not all important what is important is the power the engine makes,remember horsepower is basicly a function of flow thru the engine and its related components, a stock 440 making 375hp may live happily with a dual 2½" system while a little mean 350ish cube motor making 800hp may not be happy at all with dual 3" pipes,mufflers have a big part in the exhaust systems capability to suport big flow aswell.
on a 370cube gen3 hemi i would build 3" duals with good freeflowing mufflers. a stock 370cube gen3 hemi is at the end of what 2½ will suport add a few speedparts and you will get to the level where 3" start to make more power.
only drawbacks with 3" over 2½" is weight and it gets alitle harder to get the tone down especialy at idle and at full power.
Re: 6.1 swap - proper exhaust size? [Re: 1Fast340] #1183823
02/24/12 08:25 PM
02/24/12 08:25 PM
Irving, TX
feets Offline
Senior Management
feets  Offline
Senior Management
Irving, TX
What you left off of your post was engine efficiency.
The new engines are more efficient than our old dinosaurs. That means they make more power with less fuel and air.
Lower air requirements mean lower exhaust volume.
They will make more power with a 2-1/2" pipe than a 440 or 383.
- Stu Harmon
Re: 6.1 swap - proper exhaust size? [Re: feets] #1183824
02/24/12 08:47 PM
02/24/12 08:47 PM
Canada
WO23Coronet Offline
WO23Coronet  Offline
Canada
Yeah the new engines are more volumetrically efficient generally but you still need a certain amount of air to make a HP number, it doesn't matter what the efficiency is, it just needs the right size pipe to move how much air its moving (cu inches X efficiency). I look at it like this, theoretically, HP is soley dependant on CFM of a head, cubic inches just determine what RPM it happens at. Most exhaust size calculators I look at peg a dual 2.5" system at 500 hp (gross), which a good stock 6.1 is very close to. I would go 3" and give yourself some room to breath
