2004 chrysler 300m transmission problems! #1183706
02/21/12 10:32 PM
02/21/12 10:32 PM
Just South of The Motor City
limechallenger Offline OP
My 2004 Chrysler 300m seems to be downshifting then upshifting as I drive along at 60-70 mph! it shifts back and forth so quick the tach doesn't even move however sometimes the speedometer does drop a bit. This happens randomly with no consistancy, sometimes I'll drive 30 miles and it won't happen then it starts for a couple miles.The tranny seems to shift fine around town,stop light to stop light , corners etc.... Only have the problem at highway speed. Any help, ideas,suggestions?
70 T/A Challenger 78 Aspen R/T 87 Indy 500 Dakota
Re: 2004 chrysler 300m transmission problems! [Re: limechallenger] #1183707
02/22/12 09:30 AM
02/22/12 09:30 AM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
First thing I would do is have it scanned for codes. Could be one of the speed sensors but if it has a code diagnose for that. Ron
Re: 2004 chrysler 300m transmission problems! [Re: limechallenger] #1183708
02/22/12 11:40 AM
02/22/12 11:40 AM
It's a dry heat
gtx6970 Offline
gtx6970  Offline
It's a dry heat
Sounds like it's going in and out of lockup
'most likely' issue is the Throttle position sensor is failing. ck it with a lab scope to be sure. If it slight a ohm meter will never catch a problem
BUT
it could be a multitude of issues from a failing torque conv. clutch to a valve body issue
