73 duster biggest wheel tire you can put on back #1183672
02/21/12 09:32 PM
02/21/12 09:32 PM
Central Missouri Fort Leonard...
mopar65 Offline OP
mopar65  Offline OP
well i am going to be building a 73 duster i hope soon.SO was wondering whats the biggest wheel and tire.That i can put on the rear with a stock tub and the springs in the factory location? thanks Mopar65
3520 pound race ready 1973 Street/Strip Dodge Dart - Stock stroke 440/727 10.49 @ 125.0 on 93 pump gas & ET Street Radials. More to come... ( SGT Miller) Proudly served 12 years in the US ARMY RESERVES support our troops
Re: 73 duster biggest wheel tire you can put on back [Re: mopar65] #1183673
02/21/12 09:48 PM
02/21/12 09:48 PM
organ
maximum entropy Offline
organ
if you get the backspacing just right, you'll be able to fit the largest tire possible. any larger than that, and you've got trouble, mister.
Re: 73 duster biggest wheel tire you can put on back [Re: maximum entropy] #1183674
02/21/12 09:50 PM
02/21/12 09:50 PM
mopar65 Offline OP
mopar65  Offline OP
hey thanks for the great info.lol
Re: 73 duster biggest wheel tire you can put on back [Re: mopar65] #1183675
02/21/12 10:10 PM
02/21/12 10:10 PM
MN
dustyswinger Offline
MN
I have a 73 with cal trac mono leafs, I put a 1/8 in spacer between the spring perch and the spring pocket on the front of the spring. I can fit a 30X9 Hoosier radial in it with a 15X8 wheel with 4.5 back space.
Re: 73 duster biggest wheel tire you can put on back [Re: dustyswinger] #1183676
02/21/12 10:25 PM
02/21/12 10:25 PM
mopar65 Offline OP
mopar65  Offline OP
thanks for the info. for now i will be running the mopar 002/003 super stock springs.so it sounds like my weld drag lights that are a 15x8 wheel with 4.5 back space and some M/T 275/60/15 E/T street drag radials would fit then? got any pics of your car? thanks Mopar65
Re: 73 duster biggest wheel tire you can put on back [Re: mopar65] #1183677
02/21/12 10:41 PM
02/21/12 10:41 PM
long island NY
Ari440 Offline
Ari440  Offline
long island NY
295 65 15 on a 15x8 inch rim and 29.5 10.5 15 m/t slicks on a 10 inch rim 5 inch b/s
dana 60 is 54 inchs long
you need to cut the front lowwer quater panal and roll the wheel lip in
1.39 9.85 - 137 mph
Re: 73 duster biggest wheel tire you can put on back [Re: mopar65] #1183678
02/24/12 02:58 AM
02/24/12 02:58 AM
MN
MN
Here you go
Re: 73 duster biggest wheel tire you can put on back [Re: dustyswinger] #1183679
02/24/12 10:20 PM
02/24/12 10:20 PM
Kentucky
clovis Offline
clovis  Offline
Kentucky
i have a '75 and I was able to get a 28x10.5 MT ET drag under it on a 15x8. I had a b body 8 3/4 so I had 5.5 for backspacing.
'75 Plymouth Duster
Phase I 451 906/590/2-660 10.75/126
Phase II 451 Stage VI/590/1050 9.82/135
Phase III 383 906/Victor-Pump gas 11.30/119
"For by grace you have been saved through faith. And this is not your own doing; it is the gift of God,"
