Re: edelbrock heads
[Re: can.al]
#1183569
02/21/12 06:37 PM
02/21/12 06:37 PM
Posts: 864 St Paul MN
73swinger
St Paul MN
From Edelbrock website
HEAD BOLTS or STUDS: High quality head studs or head bolts with hardened washers must be used to prevent galling of the aluminum bolt bosses. Edelbrock Head Bolt Kit #8555 includes two longer-than-stock bolts which must be used with these cylinder heads. If you use any other head bolts, you must use the two head bolts and washers supplied with these heads in position #5 in Fig. 1. This position will not accept stock length head bolts.
That said, I think the 2 bolts were supplied with mine when I bought them, but that was years ago.
Chris Schwartz
73 Swinger 340 12.451 @ 108.78
73 Gold Duster, needs a plan.
Re: edelbrock heads
[Re: 73swinger]
#1183570
02/21/12 06:57 PM
02/21/12 06:57 PM
Challenger 1
Cincinnati, Ohio
Exactly, they send 2 bolts with the heads, I invested in new bolts and washers all the way around when I finally put mine on in 2007. I used the KB 243 hyper piston which stuck out about .029" which was good with the open chambered eddie heads designed for early higher compression 340s.
