Page 1 of 3 1 2 3
well im now in the tunnel ram club- i have a question #1183387
02/21/12 10:57 AM
02/21/12 10:57 AM
mckinney texas
shoebox Offline OP
shoebox  Offline OP
mckinney texas
i just got my TR last night, its a weiand 5987 stage2. no cracks,mods,stripped holes etc. looks real good. when you look into the tops you can see where the upper meets the lower. there is a step there. like the lower openings need to be ported. is that a MUST DO? have you seen it worth 20 horse on the dyno? if i can leave it thats ok. stock stroke 440, 4800stall 6500rpm tell me anything you know of the history about the stage2.. any good?
74 dart sport 440 www.Csucarbs.com
Re: well im now in the tunnel ram club- i have a question [Re: shoebox] #1183388
02/21/12 01:43 PM
02/21/12 01:43 PM
Sweet Home Alabama
MRMOPAR622 Offline
MRMOPAR622  Offline
Sweet Home Alabama
I had a weiand a few years back & spent the $$$ to have not just that but the ports gasket matched they were off quite a bit,you might want to see how close the ports match the gaskets as well. If I did not want to invest the $$$ to pay someone to do it I would take the die grinder and only go down a inch or two and blend them in some.
"To Be The Man'You Have Got To Beat The Man" "T/D and Pro-Bracket Racer"
Re: well im now in the tunnel ram club- i have a question [Re: MRMOPAR622] #1183389
02/21/12 02:15 PM
02/21/12 02:15 PM
mckinney texas
shoebox Offline OP
shoebox  Offline OP
mckinney texas
SOUNDS GOOD
Re: well im now in the tunnel ram club- i have a question [Re: shoebox] #1183390
02/21/12 02:19 PM
02/21/12 02:19 PM
bigfork mn
dragram440 Offline
dragram440  Offline
bigfork mn
I really would like to do a tunnel ram. What did you have for a carb and intake? or is this a new build? What carbs are you going with?
67' charger 499 RB 10.57 at 127
Re: well im now in the tunnel ram club- i have a question [Re: dragram440] #1183391
02/21/12 03:29 PM
02/21/12 03:29 PM
mckinney texas
shoebox Offline OP
shoebox  Offline OP
mckinney texas
I'm just getting started. I'm collecting parts at this time
Re: well im now in the tunnel ram club- i have a question [Re: MRMOPAR622] #1183392
02/21/12 03:30 PM
02/21/12 03:30 PM
All of the tunnel rams I've seen have that problem, including two M1 tunnel rams Port match them on the two halves
Re: well im now in the tunnel ram club- i have a question [Re: Cab_Burge] #1183393
02/21/12 04:10 PM
02/21/12 04:10 PM
organ
maximum entropy Offline
organ
just a clean up would prolly work wonders, and a deep port match.
Re: well im now in the tunnel ram club- i have a question [Re: maximum entropy] #1183394
02/21/12 04:54 PM
02/21/12 04:54 PM
PA
70HemiGTX Offline
70HemiGTX  Offline
PA
That's what I did with mine.
Re: well im now in the tunnel ram club- i have a question [Re: 70HemiGTX] #1183395
02/21/12 09:31 PM
02/21/12 09:31 PM
Sweet Home Alabama
MRMOPAR622 Offline
MRMOPAR622  Offline
Sweet Home Alabama
These intakes work great with 2 4779 carbs. with choke horns milled off sq jetted @ 80 with power valve block off on a strong 440-451 engine like yours.
Re: well im now in the tunnel ram club- i have a question [Re: MRMOPAR622] #1183396
02/21/12 09:48 PM
02/21/12 09:48 PM
Central Missouri Fort Leonard...
mopar65 Offline
mopar65  Offline
well i too like the tunnel-ram. when i had my mopar m1 i was running 2 pretty much box stock carter comp 750 carbs.my best time is in my sig with them.i just put the weiand stage 2 tunnel ram on my dart but have not had a chance to try it out yet with the carter carbs.But i am going to be putting on a set of Holley 650 dp on it soon. what would you recommend for jetting? also was thinking about buying a set of eather holley or profrom main bodys for it. the two halves of my intake did not match up very well at all. so i bolted it together and port matched the two halves came out great i thought.Mopar65
3520 pound race ready 1973 Street/Strip Dodge Dart - Stock stroke 440/727 10.49 @ 125.0 on 93 pump gas & ET Street Radials. More to come... ( SGT Miller) Proudly served 12 years in the US ARMY RESERVES support our troops
Re: well im now in the tunnel ram club- i have a question [Re: mopar65] #1183397
02/21/12 10:01 PM
02/21/12 10:01 PM
mckinney texas
shoebox Offline OP
shoebox  Offline OP
mckinney texas
Mopar65... Lil off topic but what headers are you running? I have a pic
Of your engine with the m1 TR and the primaries look small like
Schumakers. TTI's?
Re: well im now in the tunnel ram club- i have a question [Re: shoebox] #1183398
02/21/12 10:08 PM
02/21/12 10:08 PM
mopar65 Offline
mopar65  Offline
Schumakers. TTI's?
shoebox sorry for high jacking your post with my tunnel-ram ram question and i will start my own post on that. but to answer your question my car has the tti 2 inch tube 3-1/2 collector.any more questions fill free to ask.thanks mopar65
Re: well im now in the tunnel ram club- i have a question [Re: mopar65] #1183399
02/21/12 10:34 PM
02/21/12 10:34 PM
mckinney texas
shoebox Offline OP
shoebox  Offline OP
mckinney texas
No no I meant I was off topicing my own thread! You can ask anything
You want right here!
Re: well im now in the tunnel ram club- i have a question [Re: shoebox] #1183400
02/21/12 10:36 PM
02/21/12 10:36 PM
long island NY
Ari440 Offline
Ari440  Offline
long island NY
two 750s 80 jetts on a indy tunnelram
1.39 9.85 - 137 mph
Re: well im now in the tunnel ram club- i have a question [Re: Ari440] #1183401
02/22/12 01:23 PM
02/22/12 01:23 PM
mckinney texas
shoebox Offline OP
shoebox  Offline OP
mckinney texas
Dual AFB's sure would be easy as far as facing forward, linkage etc
They look good too! Mopar65 do they drive nice?
Re: well im now in the tunnel ram club- i have a question [Re: shoebox] #1183402
02/22/12 01:29 PM
02/22/12 01:29 PM
Riverside, California
Lil Demon Offline
Lil Demon  Offline
I run an Indy TR with twin 1050s. My TR is box stock and the ports are smaller than my heads but talking to Jeff at Modern he said it would cost around $500 to port match it and it would only net maybe 15hp. Not worth messing with it IMHO and I can get more bang for that $500 elsewhere in the car.
Re: well im now in the tunnel ram club- i have a question [Re: Lil Demon] #1183403
02/22/12 03:24 PM
02/22/12 03:24 PM
Kentucky
clovis Offline
clovis  Offline
Kentucky
Sometimes there is a little wiggle room between the top and base, so you might try to unbolt it and see how much movement there is before you start grinding. It would be worth a look to take the top off and set the intake on the heads to see how closely the ports match up.
As far as tunnel ram carbs for a race car, I like the 4224s (660 center squirters). They need their idle circuit leaned out, but that can be fixed with a piece of wire. For wide open use, they are hard to beat, that is why they are also popular with the boat boys. Grumpy was a little partial to them also. You can set them end to end and still get the bowls off, so the linkage is also straight forward.
'75 Plymouth Duster
Phase I 451 906/590/2-660 10.75/126
Phase II 451 Stage VI/590/1050 9.82/135
Phase III 383 906/Victor-Pump gas 11.30/119
"For by grace you have been saved through faith. And this is not your own doing; it is the gift of God,"
Re: well im now in the tunnel ram club- i have a question [Re: clovis] #1183404
02/22/12 03:43 PM
02/22/12 03:43 PM
mckinney texas
shoebox Offline OP
shoebox  Offline OP
mckinney texas
I talked with my carb guy and hes got a set of 650 holleys set aside with my name on em!
i wonder should i get the weiand linkage kit or AED or ???brand ? sideways setup.
Re: well im now in the tunnel ram club- i have a question [Re: shoebox] #1183405
02/22/12 05:22 PM
02/22/12 05:22 PM
Carson City, Nevada
Biginchmopar Offline
Carson City, Nevada
My tunnel ram is a M1 and it has two 9379 (750) mounted side ways and it has the AED linkage.
Re: well im now in the tunnel ram club- i have a question [Re: Biginchmopar] #1183406
02/22/12 05:32 PM
02/22/12 05:32 PM
mckinney texas
shoebox Offline OP
shoebox  Offline OP
mckinney texas
COOL! looks nice!
Page 1 of 3 1 2 3
