engine wire harness needed #1183308
02/21/12 08:37 AM
02/21/12 08:37 AM
Ohio
RonaldV Offline OP
RonaldV  Offline OP
Ohio
The engine harness on my 65 D100 is crusty. I need a new one and want to modified to be for electornic ignition. Who is your recommended source for this??
Thanks!
Re: engine wire harness needed [Re: RonaldV] #1183309
02/22/12 03:08 PM
02/22/12 03:08 PM
Ohio
RonaldV Offline OP
RonaldV  Offline OP
Ohio
anybody?? I know there was a recommended company in the past that would customize a new harness to fit your needs.
Re: engine wire harness needed [Re: RonaldV] #1183310
02/22/12 08:47 PM
02/22/12 08:47 PM
Utah and Alaska
astjp2 Offline
astjp2  Offline
Utah and Alaska
Try M&H, they might custom build you one. Tim
Re: engine wire harness needed [Re: astjp2] #1183311
02/22/12 10:04 PM
02/22/12 10:04 PM
Back home in PA
BulletBob Offline
BulletBob  Offline
Back home in PA
Why not buy a Factory shop manual & sit down & rebuild what you have & get the wiring for the electronic ignition from a donor or a vendor.
I have in the past robbed a harness from a 72-77 Dodge truck & made it fit to gain extra circuits.
73-84 Chevy truck harness can be cut down to fit & is actually the easiest. You get fuse links & all. You can use the 84-85 harness with OD & get the switches & harness to use for a 518 Just get the 2 pressure switches & you have a PATC style lockup kit
Re: engine wire harness needed [Re: RonaldV] #1183312
02/22/12 10:42 PM
02/22/12 10:42 PM
Medford OR
FrankenScamp Offline
Medford OR
Probably not much plug and play out there new, used I'm sure.
I'm another for DIY. Bought new bulkhead connections and did the "mad" conversion. Now all the wiring from the fire wall forward is new. Make good soldered connections and wrap it all up in vinyl wrap. Not electrical tape.....
Good luck!
Re: engine wire harness needed [Re: FrankenScamp] #1183313
02/23/12 02:30 AM
02/23/12 02:30 AM
Back home in PA
BulletBob Offline
BulletBob  Offline
Back home in PA
Solder & heat shrink, the Chevy truck harness is basically what the Painless & other vendors designed off of. I use them from headlight to tail light
Re: engine wire harness needed [Re: BulletBob] #1183314
02/23/12 05:38 AM
02/23/12 05:38 AM
DELAWARE
bee71mopar Offline
bee71mopar  Offline
DELAWARE
Try evanswiring.com he used to remake harnesses for others.
Re: engine wire harness needed [Re: bee71mopar] #1183315
02/23/12 10:57 PM
02/23/12 10:57 PM
Ohio
RonaldV Offline OP
RonaldV  Offline OP
Ohio
Thanks for the tips. I HATE electrical. Im also on a time crunch and I dont want to do this from scratch. Ill farm this out if I can. I want to be driving by spring.
RV
