What ladder Bar Length??
#1182957
02/20/12 06:09 PM
02/20/12 06:09 PM
Posts: 1,552 Michigan
Kiddart
I have a 74 Dart sport. I am kicking around doing a ladder bar set up to it. What length laddet bar would I use?? Any Reply is appreciated!! Kiddart
Thank you Kiddart
Re: What ladder Bar Length??
[Re: dennismopar73]
#1182959
02/20/12 07:43 PM
02/20/12 07:43 PM
Kiddart
what will 36inch do different thaty 32 or 31.5. and does the bottom bar have to be parralel with the ground perfectly?
Thank you Kiddart
[Re: Kiddart]
#1182960
02/20/12 07:56 PM
02/20/12 07:56 PM
Posts: 43,185 Bend,OR USA
Cab_Burge
The longer bars have more leverage is what I've been told and they have more lift from the longer leverage. I would put the longest ones on the car that will fit nice, look closely at all the things needed and what they will hit or interfere with under the car before deciding My car is a street and strip car that I wanted to sit real low, just like a stock grandmas 6 cylinder cars do so I had mine installed with that in mind The chassis guy cut and installed narrow boxes into the floor so the back of the car could be lowered down and not hit the RJ 1/4 Max ladders in any position or ride height As far as the bottom bar and the angles you will need to find out what your car likes, not all of our cars are identicle, weight distribution, power, tire sizes and so on I have mine in the bottom hole on the front ladder bar mount cross member, it hooks very well, 1.43 60 ft. times and low tens at 134+ MPH with the mufflers on, pump gas, ET Street tires and motor only It will hook in a mud puddle in the middle of a rain storm It does work very well, you do need to work on both ends of the car to make it work the best it can
