I'm not getting any spark 79 360 motor #1182930
02/20/12 05:22 PM
02/20/12 05:22 PM
ME
79machocharger Offline OP
ME
So I just installed a 360 back into my lil red and I'm now trying to get it fired up. I seem to have it all wired up right but I'm not getting any spark. I've checked with a test light and with the key on position I have power at the positive side of the coil, power at both sides of the ballast resistor. I've also swithed the ecu box out with new and installed a new distributor. I'm almost ready to take the engine harness out and switch it with one on a parts truck that I have that I know is good. The coil also came off a running truck as well. Any help on where to look now would be awesome, thanks!
Re: I'm not getting any spark 79 360 motor [Re: 79machocharger] #1182931
02/20/12 05:26 PM
02/20/12 05:26 PM
Kent, Wa
340SHORTY Offline
Truck Nut
340SHORTY  Offline
Truck Nut
Kent, Wa
Is the air gap right?
Maybe the pickup unit is bab.
Rotor in the dist?
I am truckless..
Re: I'm not getting any spark 79 360 motor [Re: 340SHORTY] #1182932
02/20/12 05:37 PM
02/20/12 05:37 PM
ME
ME
The distribitor is new and came out of my cuda which was running so it should be fine.
Re: I'm not getting any spark 79 360 motor [Re: 79machocharger] #1182933
02/21/12 02:24 AM
02/21/12 02:24 AM
Niwot, CO Formerly denn...
dynorad Offline
dynorad  Offline
If you have another running vehicle (your Cuda for example) you can swap your parts onto it one at a time to verify good parts. The other thing you can do is compare voltages through the system between the two.
I like to "bench test" with the distributor out but connected and grounded. You can spin the shaft and make sparks without running the battery down with the starter.
Re: I'm not getting any spark 79 360 motor [Re: 79machocharger] #1182934
02/21/12 10:56 PM
02/21/12 10:56 PM
Middle TN.
4x4 Roundup Offline
4x4 Roundup  Offline
Middle TN.
'79 318's have an EGR timer that will cause "no spark" when it goes bad...must be replaced or bypassed.
Just a thought...being a truck person you probably already knew that.
WANTED-- DEAD or ALIVE:
'70 Duster--- VS29H0B274908-----UPDATE---ENGINE BLOCK FOUND---Still looking for the B-5 car.
'79 Power Wagon W14JE9S137761 or 763
Re: I'm not getting any spark 79 360 motor [Re: 79machocharger] #1182935
02/21/12 11:46 PM
02/21/12 11:46 PM
Checking the "start" side: take off the yellow "sol" wire from the starter relay to disable the starter to keep from unneccesarily running the batt down. Take off any/all wires from the coil neg primary terminal and with a jumper wire w alligator clips on each end/clip one to the male pri neg coil terminal and tap tap the other clip to ground repeatedly like Morse Code as a helper holds the key to "start" & if the coil secondary wire (dist end) held 1/4" from ground sparks this tells you the ign sw/coil/their supporting wiring (the "start" circuit) is good and that the prob is the ECU/ECU ground/dist pickup or one of their supporting wiring circuits. Holler back & more later. In a 5 pin ECU/4 male terminal ballast system (2) terminals in the ECU must be hot in "start" + bypassed 12V to the coil positive pri terminal
Re: I'm not getting any spark 79 360 motor [Re: 4x4 Roundup] #1182936
02/22/12 11:12 AM
02/22/12 11:12 AM
ME
ME
I think I may of removed that EGR timer harness. Not really sure how to bypass it. I'll look into that. I have a complete EGR set up on my 80 that I could take off and put on this truck. Thanks for your help.
