360 rods in 318 block #1181892
02/19/12 03:58 AM
02/19/12 03:58 AM
waco tx
gogo318 Offline OP
gogo318  Offline OP
waco tx
what if i put 360 rods in a 318 could it even be done? would it make a 340 lol just curious
67 charger fastback 318 stock 67 belvedere II 4dr soft top built 318 68 newport 2dr hard top 318 84 b150 440/727 84 d150 short wheel step side 4x4 lifted 87 omnitruck (you just have to see it ) new addition 63 dart wagon !!!
Re: 360 rods in 318 block [Re: gogo318] #1181893
02/19/12 05:04 AM
02/19/12 05:04 AM
Kent, Wa
340SHORTY Offline
Truck Nut
340SHORTY  Offline
Truck Nut
Kent, Wa
NO
I am truckless..
Re: 360 rods in 318 block [Re: 340SHORTY] #1181894
02/19/12 06:15 AM
02/19/12 06:15 AM
Back home in PA
BulletBob Offline
BulletBob  Offline
Back home in PA
Those rods are 6.123 long & are the same as your 318 so making a 340 is out of the question
Re: 360 rods in 318 block [Re: gogo318] #1181895
02/19/12 10:15 AM
02/19/12 10:15 AM
Marysville, O-H-I-O
70Cuda383 Offline
70Cuda383  Offline
Marysville, O-H-I-O
the size of the engine is calculated by using the size of the bore, and the length of the stroke--how much the piston moves up and down, which is determined by the crankshaft only.
what pistons, rods, heads, etc. you use, will not have any effect on what size the engine is.
**Photobucket sucks**
Re: 360 rods in 318 block [Re: gogo318] #1181896
02/19/12 10:52 AM
02/19/12 10:52 AM
Posting from 1893 in NW FL
TheBlueBeast Offline
no.
the 340 is the same stroke as the 318 but has a bore of just over 4 inches. You can not bore the 318 enough before you clear the cylinder wall.
the 360 also has a larger journal on the rod than the 318 has on the crankshaft. IIRC And there is no way to make the rod fit properly onto the smaller diameter crankshaft.
And no you can not destroke a 360 back down to a 340 with a 318 crankshaft. unless you want to spent lots and lots of money in research and development and machine work.
Re: 360 rods in 318 block [Re: gogo318] #1181897
02/19/12 10:59 AM
02/19/12 10:59 AM
I think the later 318's got the "645" 360 rods
Re: 360 rods in 318 block [Re: TheBlueBeast] #1181898
02/19/12 11:41 AM
02/19/12 11:41 AM
scratchnfotraction Offline
no.
IIRC..the main bearings are larger on the 360 crank,they both use the same rods.
they did make main bearing spacers that would allow you to run a small main bearing 318 crank in the 360 block to destroke it.
putting a 360 crank with the mains cut down to 318 size with a stock 318 bore will make a 346 cubic inch and with a .030 over bore and stroker pistons you get a 349 cubic inch.
use of a 4" stroke crank in a 318/340 will get you 390/416 cubic inch stroker
use of a 4" stroke crank in a 360 will get you 408 cubic inch stroker
just boreing a 318 out .030 will get you a 323 cubic inch
I am doing up a 349 roller cam stroker engine myself
Re: 360 rods in 318 block [Re: TheBlueBeast] #1181899
02/19/12 11:42 AM
02/19/12 11:42 AM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
no.
BZZZT!
Rod journals are the same, later 318s ran the same rods as the 360. Main journals are where the difference lies.
If you 318 already runs the 360 rods you can swap no sweat. If it has the early light 273/328 rods you may have to rebalance. Other than the, no problem swapping.
Don't be the exception.
Re: 360 rods in 318 block [Re: Supercuda] #1181900
02/19/12 11:49 AM
02/19/12 11:49 AM
OK. I stand corrected.
But to the original poster's question we still did not make a 318 into a 340.
Bigger? Yes
Smaller? Yes.
BTW I was unaware that there was a change in the 318/360 to make parts interchangable. Did this happen in the mid eighties or on the magnum motors?
Re: 360 rods in 318 block [Re: TheBlueBeast] #1181901
02/19/12 12:14 PM
02/19/12 12:14 PM
Bigger? Yes
Smaller? Yes.
mag rods are thinner on the small end.
IIRC the change over when they droped the 273 with floating pins,not sure,never had any of the early rods myself.
Re: 360 rods in 318 block [Re: scratchnfotraction] #1181902
02/19/12 12:38 PM
02/19/12 12:38 PM
Leucadia, Ca.
V
vdriver Offline
vdriver  Offline
V
Leucadia, Ca.
I've torn down 4 318's in the last 2 years, the oldest a late '72 casting from a '73 Valiant; the newest an '86 roller. They all had the heavier '645 (340/360) rods with pressed pins. The '72 bearing shells were dated late '72 so I'm sure it was a virgin motor.
Re: 360 rods in 318 block [Re: scratchnfotraction] #1181903
02/19/12 12:47 PM
02/19/12 12:47 PM
from the chilton's repair manual for 1975, page C336, chart Crankshaft and connecting rod specifications.
The Journal Diameters for the connecting rods from 1968 through 1975 for all listed small blocks (273-360) is actually the exact same 2.124-2.125 inches.
I am very impressed with your knowledge. I was misinformed.
Re: 360 rods in 318 block [Re: TheBlueBeast] #1181904
02/19/12 01:40 PM
02/19/12 01:40 PM
Kalispell Mt.
HotRodDave Offline
HotRodDave  Offline
Kalispell Mt.
Basically 4 different SB rods used through the entire production run includeing the poly 318.
1. The 273 and 318 through 71 used the lightest version with bushed small ends.
2. The 340 came out with a slightly beefier rod (all other rods were variations of this one)with a bushing and floating pins.
3. Some time in 71 they came out with an unbushed 340 rod for use in the 360 and 318 until 92 for the 318 and 93 for the 360.
4. When they went to magnum engine desighn in 92 and 93 they used the same basic rod still but they narroed the top end.
All rods are the same length and journal diameters. You can use the magnum style rod in ANY older SB (balance should be checked). The pressed fit 318 360 LA rod can be used in any other SB (they need narrowed small end to fit in a magnum). The early bushed rods can be used in any engine with floating style pistons, some 340 guys will run the lighter 273 318 floating rod to lighen it up, I have seen some of the heavier 273 318 rods that weighed as much as the lighter of the 340 rods, the weights are all over teh place.
Re: 360 rods in 318 block [Re: 340SHORTY] #1181905
02/19/12 10:54 PM
02/19/12 10:54 PM
waco tx
gogo318 Offline OP
gogo318  Offline OP
waco tx
great info guys sorry it didnt dawn on me that the crank is what modifies the stroke not the rods (laughs at self) but now im really curious what about the pistons from a 360 could i get them on a 318 rod and bore out my holes to take them just asking cause im about to rebuild the virgin 318 that gose in my belvedere and i got some 360 guts that im likely to never use unless some find there way into this engine ps im not actually tring to build a 340 it was more of a joke
Re: 360 rods in 318 block [Re: gogo318] #1181906
02/19/12 11:20 PM
02/19/12 11:20 PM
no,cant bore the 318 block that much,would need a sonic check and be real thin if it did get bored to that piston specs.
cut the 360 crank mains down,get the .030 over 349 stroker pistons,bore your 318 block.
they say you can use some early 318 pistons that are way down in the hole on the 360 crank/318 block,just need to clearance the piston pin boss and skirt to clear the crank weights.
that will make the 346 cubic inch stroker on the cheap.
i just opted for the 349 pistons with the roller cam 318 block..
member "performance only" can cut the 360 crank and take care of the raer oil seal cut with a more than fair price.
Re: 360 rods in 318 block [Re: scratchnfotraction] #1181907
02/20/12 01:44 AM
02/20/12 01:44 AM
dogdays Offline
dogdays  Offline
Unless machine work is really cheap where you are, a 4" crank and pistons would get you more cubes for the buck.
If you wanted to go the 360 crank stroker route I'd use 360 "645" rods and LC371P sealed power pistons, with 360 heads. There are three 318 pistons for ultra low compression that have a 1.658" compression height which is almost exactly what a 360 piston is. I remember that one.
R.
Re: 360 rods in 318 block [Re: dogdays] #1181908
02/20/12 02:51 AM
02/20/12 02:51 AM
las vegas
70AARcuda Offline
70AARcuda  Offline
las vegas
just make sure the "318 pistons" skirts clear the counterbalances on the cut down 360 crank...
scat make a 3.58 stroke crank with 318 bearing size...
Tony
70 AARCuda Vitamin C
Re: 360 rods in 318 block [Re: gogo318] #1181909
02/20/12 03:40 AM
02/20/12 03:40 AM
The Dalles, OR.
Dusted_Ya Offline
Dusted_Ya  Offline
The Dalles, OR.
ALL small block rods are interchangable for the most part with minor variations.
273-318 rods were the same for cars up until 1970 (light duty)
70-2 car and 68-73 truck 318's shared the same floating pin rod as the 340.
All 360's used the same rod as the previously mentioned floating 318-340 rod only with a pressed pin up until 1994 when the 318-360 went to magnum design which is essentially still the same rod only with a narrower width (on the machined side) as Scratch mentioned.
If putting 360 rods in a 318 made a 340 I'd put cummins rods in a 440 to make a 572 monster! But unfortunately it doesn't work that way.
Retired Mopar fanatic
Re: 360 rods in 318 block [Re: 70AARcuda] #1181910
02/20/12 01:22 PM
02/20/12 01:22 PM
dogdays Offline
dogdays  Offline
It's not the skirtsthat are the major issue.
You may have to grind a little off the piston pin bosses for clearance but that will help balance as 360 pistons are about 20 grams lighter than 318s, so you're getting the 318 piston to be closer to the 360 piston weight.
It's been done before. Speedomotive used to sell a cheap 349 kit that could only have used the LC cast pistons and I believe they did the cleanup on the pistons for clearance.
R.
