440 pilot bearing part number? Not bushing!
#1181610
02/18/12 04:47 PM
02/18/12 04:47 PM
Posts: 473 Fort Lauderdale, FL
Suregrip
Fort Lauderdale, FL
Anyone have a good Chrysler or NAPA part number for a pilot bearing, not a bushing, that I can use in the end of a steel carnk 440 in front of a 833 trans? I used the bronze bushing last time, but heard there is an actual bearing I can use instead? I have also seen that a mid nineties pilot bearing for a 360 RAM works as well?
Some people you just can't reach...
Re: 440 pilot bearing part number? Not bushing!
[Re: Stanton]
#1181614
02/18/12 10:14 PM
02/18/12 10:14 PM
Suregrip
Fort Lauderdale, FL
Not looking for horsepower! The bushing I removed was paper thin after twenty two years of heavy use. I was looking for durability... No one locally had the bearing, so back in goes another bushing!
[Re: Suregrip]
#1181615
02/18/12 10:24 PM
02/18/12 10:24 PM
Posts: 1,407 northeast ohio
hulmule
northeast ohio
wow glad i saw this picture.doing a motor swap on a 99 dakota 3.9 v6, has a pilot bearing in place in the old motor.How do i get out the old one? plus the clutch kit sent me a bushing.i must have to knock out the old bearing and install the bushing in place of the old bearing.does that make sence?
1969 Dodge Coronet R/T Convertible 1979 LiL Red x2 2012 Yellow Jacket 2006 mega cab 1977 Trailduster 1979 Trailduster
[Re: Suregrip]
#1181617
02/19/12 12:38 AM
02/19/12 12:38 AM
Posts: 8,871 Ontario, Canada
Stanton
Don't question me!
Don't question me!
Ontario, Canada
Then consider yourself lucky that you had a bushing in there and not a bearing! Something had to be out of whack to cause the bushing to wear. Had it been a bearing you would have had balls and other bits of metal flying around in the bellhousing and the crank and trans pilot shaft would both likely have been junk.
[Re: Finoke]
#1181618
02/19/12 10:20 PM
02/19/12 10:20 PM
Posts: 4,799 ILL
MLR426
ILL
Someone posted this awhile back...
Those are great products and the only bearing to use.
logan426
[Re: MLR426]
#1181619
02/19/12 11:07 PM
02/19/12 11:07 PM
Posts: 1,212 Canton, Ohio
Crazy68Dart
Canton, Ohio
I just went through this. The 4338876 is discontinued, I had to get one from a dealer in Indiana which had exactly one on the shelf. To me the bushing is just one less thing to fail. Here are my notes: The "AB"s are what the discontinued part crossed over as the replacement. 4338876 - Old PN for discontinued crank register style bushing 53009180AB hub register style sleeve & roller bearing 53009181AB crank register style roller bearings Here is mine installed:
383, Hemi 4-Speed, AlterKtion, D60
