1972 Plymouth Satellite rear window regulator removal. #1181535
02/18/12 01:58 PM
02/18/12 01:58 PM
California
moparbroz Offline OP
California
Broken glass from years ago on a project that I am restoring. Two screws on the top edge stripped. Looks like someone long ago attempted to remove or install glass with out removing the regulator. Do I grind off the two screws and go from there?
Hebrews 11:1
Re: 1972 Plymouth Satellite rear window regulator removal. [Re: moparbroz] #1181536
02/20/12 03:12 AM
02/20/12 03:12 AM
California
California
No one knows?
Hebrews 11:1
Re: 1972 Plymouth Satellite rear window regulator removal. [Re: moparbroz] #1181537
02/20/12 04:21 AM
02/20/12 04:21 AM
Lethbridge, AB, Canada
dangina Offline
dangina  Offline
yes you need those screws taken off to get those "L" brackets off ad out of the way - your lucky I just did this 2 days ago on my 71 RR and took pics for future reference - and now yours, when you get those brackets off it comes out like so:
Re: 1972 Plymouth Satellite rear window regulator removal. [Re: dangina] #1181538
02/20/12 03:46 PM
02/20/12 03:46 PM
California
California
AWESOME! You rule. Thanks!
Hebrews 11:1
