Page 3 of 8 1 2 3 4 5 6 7 8
Re: Old 318 with new magnum heads...yay or nay? [Re: Dakota_Don] #1180344
02/28/12 09:29 AM
02/28/12 09:29 AM
Endicott, NY
bnichols Offline
bnichols  Offline
Endicott, NY
don the ones i have done all came out needing that length pushrod i have seen some guys say they needed longer ones etc but mine were all the same
Re: Old 318 with new magnum heads...yay or nay? [Re: 65rbdodge] #1180345
02/28/12 01:15 PM
02/28/12 01:15 PM
Marlboro, NY, USA
Rick_Ehrenberg Offline
Marlboro, NY, USA
i have seen and heard about them being cracked, but have never heard about it being a problem.
Yeah, every one has cracked exhaust seats, but work fine.
Still, the all-new Australian EQ heads flow like Edelbrocks for 1/2 the price.
The overall Magnum engine "package" has lots of other upgrades, serp. belt / tensioner, much better water pump, etc.
Keeping the OEM (junkyard) SMPI is also easy, and an AWESOME swap.
If you've gotta stay with LA heads (really bucks down), #308 castings (90-92 360) are the winners. "X" intake ports, near-W-2 exhausts.
Rick
Re: Old 318 with new magnum heads *UPDATE* [Re: Rick_Ehrenberg] #1180346
03/07/12 10:06 PM
03/07/12 10:06 PM
North Central Florida
E
eightlitermopar Offline OP
E
Well, I scoured the junkyard today and came home with a new set of heads. It took forever to get the 154 bolts (insert sarcasm here) off the front of the motor to release the heads, but I did get them.
It was off a 1996 full size dodge van. It was the 8 lug axles (so 3/4 or 1 ton I guess)....
Anyway, From the little I know they are the magnum heads. They look super clean and promising. I got the heads complete with rockers and valve covers for just over $100 bucks. I think for that price it is worth a try.
What can anyone tell me about these heads? Anything I need to know?
I know I need another intake manifold.
I know I need new pushrods...
What about the hydraulic lifters? I assume stock doesn't work, so what do I need to replace them with so I can have oiling through the pushrods?
The casting on it says 302, and the rockers are pedestal mounted, so I am thinking magnum 318.
Any thoughts?
eightlitermopar
Mopar or no car
Re: Old 318 with new magnum heads *UPDATE* [Re: eightlitermopar] #1180347
03/08/12 12:00 PM
03/08/12 12:00 PM
dogdays Offline
dogdays  Offline
Intake manifold? Modification of the existing is possible. Redrilling the heads has also been done.
Lifters? HT2011 Summit, $3.00 each. Sealed Power are a little more, I don't know where the Summit ones come from.
Look in the parts catalog, if they use the same part number for the AMC engines they're the right ones. But generally all 0.904 lifters produced by the aftermarket will be right, unless you get a really old set.
R.
Re: Old 318 with new magnum heads *UPDATE* [Re: dogdays] #1180348
03/17/12 12:51 AM
03/17/12 12:51 AM
E
E
Ok, I have the heads apart and I will be reassembling them this week.
Which head gaskets have you guys for this swap?
MAGNUM OR LA ?
I have seen online stuff say either, but I am wondering what you used and what has worked?
I have the magnum felpro gaskets, but I can get the LA ones if they are better.
eightlitermopar
Mopar or no car
Re: Old 318 with new magnum heads *UPDATE* [Re: eightlitermopar] #1180349
03/17/12 12:49 PM
03/17/12 12:49 PM
n.e. pa.
65rbdodge Offline
65rbdodge  Offline
n.e. pa.
i think you can use either head gasket. the only difference is the hole in the LA gasket allowing oil to pass through for rocker shaft oiling. the magnum head does no have the hole for oil so it will just block the hole.
Re: Old 318 with new magnum heads *UPDATE* [Re: 65rbdodge] #1180350
03/17/12 03:01 PM
03/17/12 03:01 PM
E
E
thats what I was thinking. It's hard to figure out when google search turns up both answers.
Looks like the magnum ones are the winner.
eightlitermopar
Mopar or no car
Re: Old 318 with new magnum heads *UPDATE* [Re: eightlitermopar] #1180351
03/17/12 03:13 PM
03/17/12 03:13 PM
Endicott, NY
bnichols Offline
bnichols  Offline
Endicott, NY
i have used both this motor i have now has the magnum head gaskets
Re: Old 318 with new magnum heads *UPDATE* [Re: bnichols] #1180352
03/17/12 03:17 PM
03/17/12 03:17 PM
Kalispell Mt.
HotRodDave Offline
HotRodDave  Offline
Kalispell Mt.
The factory magnum head gaskets are pretty thick, I would use the thin mopar LA head gaskets, every little bit of compression will help a lot. The extra oil hole will cause exactly ZERO issues
Re: Old 318 with new magnum heads *UPDATE* [Re: HotRodDave] #1180353
03/17/12 07:43 PM
03/17/12 07:43 PM
E
E
Hmmm...maybe I will use the LA gaskets. I have read that some people have to use sealant or something around the holes?
Should I just slap them on and torque it down?
Another question, and maybe even a request for pictures.
I know that using my 318 flat tappet cam with the magnum heads cause pushrod clearance issues.
Does anyone have a photo of where I will need to clearance the heads so this will work?
thanks! Always learnin' stuff on moparts!
eightlitermopar
Mopar or no car
Re: Old 318 with new magnum heads *UPDATE* [Re: eightlitermopar] #1180354
03/17/12 08:20 PM
03/17/12 08:20 PM
dogdays Offline
dogdays  Offline
Use the MP or Mr. Gasket thin head gaskets, I think they're 1121G, about $20 each.
You could drill and tap the oil hole and install a small setscrew beneath the deck if it bothers you to have that hole.
I thought the problem with pushrod clearance was going the other way, from roller tappet to LA heads without the large holes like the 302s have.
R.
Re: Old 318 with new magnum heads *UPDATE* [Re: dogdays] #1180355
03/18/12 01:31 PM
03/18/12 01:31 PM
E
E
Thanks for the input guys.
It looks like the Mr. Gasket head gaskets are the way I will go. After all, the bump in compression is what I like about this head swap.
I also have a pushrod length tool I will use to see exaclty what length I need for this combo. At that point I will be able to see any potential clearance issues.
I'm getting excited about seeing the difference this will make. Right now the motor runs good, but not fantastic.
Eightlitemopar.
Mopar or no car
Re: Old 318 with new magnum heads *UPDATE* [Re: dogdays] #1180356
03/19/12 08:07 AM
03/19/12 08:07 AM
USA
3
360view Offline
Moparts resident spammer
360view  Offline
3
USA
Do any of the available SB head gaskets have a 4.000 bore or are they all 4.060?
Anyone have "real world" compressed thicknesses for the various head gaskets?
Re: Old 318 with new magnum heads *UPDATE* [Re: eightlitermopar] #1180357
03/19/12 11:00 AM
03/19/12 11:00 AM
Grand Haven, MI
patrick Offline
patrick  Offline
Grand Haven, MI
Eightlitemopar.
I used these .028" thick Mr. gasket head gaskets on mine
2017 Grand Cherokee Overland
Re: Old 318 with new magnum heads *UPDATE* [Re: patrick] #1180358
10/20/12 12:42 AM
10/20/12 12:42 AM
E
E
This is an update from last spring.
I decided to wait to pull the motor until this fall. We took several family road trips over the summer and it ran well.
I now have the hunk of grease out of the car. The drivers motor mount is completely separated!
I have the magnum heads and intake, now I just need to break into the motor to see what lurks underneath.
Since this motor does not burn ANY oil and it has good power, I don't plan on doing fresh rings unless someone can really convince me otherwise. If I am going to dump a lot of money into something, I will go with a true magnum motor or a big block.
During this "freshen up" I plan on replacing:
1) All gaskets
2) New Water pump (to go along with a new radiator since the stock one is starting to leak)
3) New Oil Pump
4) New Camshaft : The cam now is visibly worn on the lobes
5) New Timing Chain.
Anything I am missig here? Any suggestions?
Anyway, that is my current update if anyone is interested!
eightlitermopar
Mopar or no car
Re: Old 318 with new magnum heads *UPDATE* [Re: eightlitermopar] #1180359
02/16/13 09:32 PM
02/16/13 09:32 PM
E
E
Here is some updated progress for anyone who is interested. I'll be ordering the pushrods soon, then it's almost done!
eightlitermopar
Mopar or no car
Re: Old 318 with new magnum heads *UPDATE* [Re: eightlitermopar] #1180360
02/17/13 01:56 AM
02/17/13 01:56 AM
Maryland
GO_Fish Offline
GO_Fish  Offline
Maryland
Looking good! You may want to mock up the alternator and see how it fits. I'm running a LA 360 with Magnum heads... Front of the motor is off the original '68 318. I'm running a later model "square back" alternator, and it was necessary to grind the front end of the passenger Magnum head for the alternator to fit right. If you are using the '69 style alternator you may or may not have this problem, but easier to check and remedy before the engine goes back in.
Scott B. "I'm a self-made man... I started with nothing, and I still have most of it!" 68 360 rusty B'cuda 'vert (GO Fish)13.59@ 98.72 mph 69 340 GTS stock 14.18@ 95.60 mph 01 5.9L Ram 1500 Quad Cab 4x4 01 3.5L 300M 16.23@ 86.97 mph
Re: Old 318 with new magnum heads *UPDATE* [Re: GO_Fish] #1180361
02/17/13 02:14 AM
02/17/13 02:14 AM
E
E
Thanks! Mocking up the front of the engine and components is next, as I am waiting for a pushrod length checking tool and a solid lifter to get here. If I may ask, what length pushrods are you using? Hydraulic lifters? I didn't think it would be so complicated to determine what lifters to use...
eight
Mopar or no car
Re: Old 318 with new magnum heads *UPDATE* [Re: eightlitermopar] #1180362
02/17/13 11:58 AM
02/17/13 11:58 AM
Columbus, GA
Michael Ecks Offline
Columbus, GA
Did anyone ever chime in on this. I've got a similar swap planned and I'm eagerly watching for updates on your set up to help figure mine out.
What are you planning on using for valve covers? IIRC old style LA covers won't clear the magnum rockers without modifying the baffles.
"The happiness of your life depends upon the quality of
your thoughts" ~ Roman Emperor Marcus Aurelius
Re: Old 318 with new magnum heads *UPDATE* [Re: eightlitermopar] #1180363
02/17/13 02:47 PM
02/17/13 02:47 PM
Maryland
GO_Fish Offline
GO_Fish  Offline
Maryland
eight
I put mine together several years ago when the MP push rods were still available. They are a little noisy, but no problems to this date. I had no push rod clearance issues, but I did check it when it was on the engine stand during assembly. I have stock '68 318 valve covers bolted to the Magnum heads, no clearance problems or modification required.
