Page 1 of 8 1 2 3 4 5 6 7 8
Old 318 with new magnum heads...yay or nay? #1180304
02/18/12 12:29 AM
02/18/12 12:29 AM
North Central Florida
E
eightlitermopar Offline OP
E
My coronet has the 318 granny motor in it. Nothing awesome, but I will be pulling it to regasket the thing (since it leaks from every possible place).
While it is out, I am afraid what I will find in regards to the 1969 castings.
Is the swap to the newer magnum heads worth it?
Should I use some iron ones I find from the local junkyard?
I will be running manifolds since it is a 4 door cruiser, but what are your experiences?
Yay or Nay? old small block heads or newer magnum castings??
Eightlitermopar
Mopar or no car
Re: Old 318 with new magnum heads...yay or nay? [Re: eightlitermopar] #1180305
02/18/12 12:31 AM
02/18/12 12:31 AM
Posting from 1893 in NW FL
TheBlueBeast Offline
gonna need an intake with new heads. straight bolts versus angled bolts. Just a "heads" up.
Re: Old 318 with new magnum heads...yay or nay? [Re: TheBlueBeast] #1180306
02/18/12 12:36 AM
02/18/12 12:36 AM
Back home in PA
BulletBob Offline
BulletBob  Offline
Back home in PA
Here's the intake you'll need to use your original stuff with on a LA360 for a 75 Fury wagon I'm doing right now with a mag head swap
Re: Old 318 with new magnum heads...yay or nay? [Re: eightlitermopar] #1180307
02/18/12 12:36 AM
02/18/12 12:36 AM
North Texas
3
360cuda Offline
360cuda  Offline
North Texas
According to the pro's, the magnum heads will flow better than the old ones do.
Re: Old 318 with new magnum heads...yay or nay? [Re: 360cuda] #1180308
02/18/12 12:39 AM
02/18/12 12:39 AM
Back home in PA
BulletBob Offline
BulletBob  Offline
Back home in PA
Here's another
Re: Old 318 with new magnum heads...yay or nay? [Re: BulletBob] #1180309
02/18/12 12:41 AM
02/18/12 12:41 AM
E
E
I knew that a new intake would be needed. that would have sucked trying to get my old one to fit
Anyway, just wondering if it delivers the difference enough to make the swap worth it.
thanks!
Eightlitermopar
ps. Do you have to get custom pushrods? Or do you use the magnum pieces?
Mopar or no car
Re: Old 318 with new magnum heads...yay or nay? [Re: BulletBob] #1180310
02/18/12 12:43 AM
02/18/12 12:43 AM
Back home in PA
BulletBob Offline
BulletBob  Offline
Back home in PA
Magnum flow better & from what I've been told are 10-12 cc's less in combustion chamber volume or 1 point in compression depending on bore size.
They're already set for unleaded gas
Re: Old 318 with new magnum heads...yay or nay? [Re: BulletBob] #1180311
02/18/12 12:50 AM
02/18/12 12:50 AM
Back home in PA
BulletBob Offline
BulletBob  Offline
Back home in PA
Summit #SUM-1457650 pushrods,AMC or aftermarket oil through Chrysler lifters,cut some casting out for the pushrods to clear & go. You can use the MP steel reinforced neoprene VC gaskets on your original VC's & keep that all original look a little
Re: Old 318 with new magnum heads...yay or nay? [Re: BulletBob] #1180312
02/18/12 12:57 AM
02/18/12 12:57 AM
Back home in PA
BulletBob Offline
BulletBob  Offline
Back home in PA
92 only truck or van Magnum manifolds are the trick. 2 1/4" outlet Requires a different dipstick & tube for the trans. What trans do you have?
Re: Old 318 with new magnum heads...yay or nay? [Re: BulletBob] #1180313
02/18/12 01:24 AM
02/18/12 01:24 AM
USA
CrAlt Offline
CrAlt  Offline
USA
Why not just keep it simple and swap on some '302 swirl port heads?
Everything you have now will bolt up. No fancy intake or manifolds needed. They are already set up for unleaded gas. And they flow better then the old 318 heads.
Look for them on a 85 or later M-body with a 2bbl or a TBI truck engine.
Magnum heads are better but if you are keeping the motor stockish i dont think they are worth all the extra crap you have to do to make them fit.
I was asked to contribute money to help solve the civil unrest in Egypt, but I suspect it's some sort of pyramid scheme.
Re: Old 318 with new magnum heads...yay or nay? [Re: eightlitermopar] #1180314
02/18/12 01:29 AM
02/18/12 01:29 AM
Alton, IL
Dakota_Don Offline
Dakota_Don  Offline
Alton, IL
go for it.. it will be like a new motor
Re: Old 318 with new magnum heads...yay or nay? [Re: CrAlt] #1180315
02/18/12 04:45 AM
02/18/12 04:45 AM
Back home in PA
BulletBob Offline
BulletBob  Offline
Back home in PA
His stock exhaust manifolds will bolt to them
Re: Old 318 with new magnum heads...yay or nay? [Re: CrAlt] #1180316
02/18/12 05:17 AM
02/18/12 05:17 AM
Glendale, AZ
69L78Nova Offline
Banned. Forever.
69L78Nova  Offline
Banned. Forever.
Glendale, AZ
Oh yes they are! Even with a MILD cam, its a night and day difference
1969 Nova
454/M21/3.31
Mild mid-11 second weekend cruiser
1994 F150 XLT Super Cab 2WD
5.0/4R70W/3.55
(Daily driver)
Re: Old 318 with new magnum heads...yay or nay? [Re: 69L78Nova] #1180317
02/18/12 05:44 AM
02/18/12 05:44 AM
Back home in PA
BulletBob Offline
BulletBob  Offline
Back home in PA
Let's see
Bigger valves
Smaller chambers
Improved version of the "swirl port"
Lighter valves
Better flow overall
1.6 Ratio Rockers instead of 1.5
Looks like it's well worth it to me
Re: Old 318 with new magnum heads...yay or nay? [Re: BulletBob] #1180318
02/18/12 06:38 AM
02/18/12 06:38 AM
Kent, Wa
340SHORTY Offline
Truck Nut
340SHORTY  Offline
Truck Nut
Kent, Wa
and a 400.== intake manifold
I am truckless..
Re: Old 318 with new magnum heads...yay or nay? [Re: 340SHORTY] #1180319
02/18/12 09:39 AM
02/18/12 09:39 AM
The Grand State of Confusion-O...
SKR8PN Offline
SKR8PN  Offline
If your going that far with the engine regasket,(new heads and intake and pushrods and lifters) you might as well re-ring it,re-bearing it and cam it while your in there. "IF" the bores are OK and within specs that is.....
Karma has no menu. You get served what you deserve.
Re: Old 318 with new magnum heads...yay or nay? [Re: BulletBob] #1180320
02/18/12 10:40 AM
02/18/12 10:40 AM
E
E
its the 904, nothing fancy.
eight
Mopar or no car
Re: Old 318 with new magnum heads...yay or nay? [Re: SKR8PN] #1180321
02/18/12 10:45 AM
02/18/12 10:45 AM
E
E
yeah....I know. The engine runs sweet. It doesn't burn oil, blow smoke, etc. (probably because it has no oil to burn! )
Of course I am exaggerating, but it does leak a bit. I hate to start looking for problems if I can avoid it.
So far this engine gets about 18-22 mpg on roadtrips. Would these heads hurt that mileage or improve it? I know that increased power means increased gas intake
eightlitermopar
Mopar or no car
Re: Old 318 with new magnum heads...yay or nay? [Re: SKR8PN] #1180322
02/18/12 11:25 AM
02/18/12 11:25 AM
USA
CrAlt Offline
CrAlt  Offline
USA
And if your going THAT far why not just find a 360?
Re: Old 318 with new magnum heads...yay or nay? [Re: 340SHORTY] #1180323
02/18/12 12:11 PM
02/18/12 12:11 PM
Back home in PA
BulletBob Offline
BulletBob  Offline
Back home in PA
[/quot
That intake in the pic is $180..00 new shipped to the door, The Performer RPM Air-Gap is $295.00 new
