413 rant...
#117990
09/09/08 11:17 AM
09/09/08 11:17 AM
Posts: 300 MA
Greg55_99
MA
OK, RANT ON! Every once in a while, I'll see the odd question about building a 413. Considering my own background with this engine, I'll have to ask.. "Why?" Nearly 30 years ago, I bought a nearly new 413 motor home engine from a guy that ran a machine shop. The motor home caught fire and burned down around the engine. The motor had less than a 1000 miles on it. Picked it up for a good price…. And that's where the whole thing goes out the window…. At that time, you could still order new factory pistons for the 413. I did. Got a set of flat tops… Of course, you ask why? Well, the motor home\truck engines come with dished low compression pistons. The engine also had a gear driven cam (that rotated backwards), heavy heads with extra coolant passages (and offer zero performance), heavy water pump housing, fat rods and an intake that weighed a ton. I essentially threw out everything that came with the engine except the block, crank, rods and oil pan and replace those with 440 items.
The point is, I'd spent lots of money… and wound up with a 440 with a smaller bore… I would have been better off just rebuilding a 440 and been done with it. So, when someone posts "I've found this 413 motor home engine for cheap and want to build it..", I say… "Pass". There are zillions of 440's waiting for some TLC…
Rant off…
Greg
Re: 413 rant...
[Re: Dakota_Don]
#117994
09/09/08 04:18 PM
09/09/08 04:18 PM
Posts: 4,861 Riverside, Ca
R70RUNNER
Riverside, Ca
Can you say "Forged crank" Boys and Girls? I knew you could. I sold the heads and pump housing for $50 and ended up with a complete RB electronic ignition, rebuilt alt, 4bbl intake, a bucket full of correct marked bolts, and a nice short block ,the '72 I got even has a 6 bolt flange, All for going to get the thing... BTW, have some plans for what to do with that dish piston turd sometime in the future CHEAP... parts are falling into place now
Current cars: 2000 Dak Quad Cab, 2012 Challenger,1970 Road Runner, 1994 Firehawk
1966 Coronet post sedan, 1988 Corvette, 2005 Magnum RT all SOLD
R70RUNNER<---VP Inland Empire Chapter of the MPM
Re: 413 rant...
[Re: Greg55_99]
#117996
09/09/08 04:51 PM
09/09/08 04:51 PM
R70RUNNER
Riverside, Ca
I see your point, but honestly if your "building" an engine, most of that stuff is going anyway. I have a ton of parts lying around from 3 other engine builds in the last 5years... so my shopping list is pushrods and cam selection Got a friendly deal on a pair of low milage 902's with stainless valves, I debated stroking it to 472, but after another buddy offered me a rebuilt/conveted 6-71 blower for the cost of parts.... Why not just shove 5-7psi through the thing and call it good for a street motor, The real problem is off the shelf piston selection. or lack there of on the 413...kills the build cost wise.
Re: 413 rant...
[Re: Greg55_99]
#117997
09/11/08 04:36 AM
09/11/08 04:36 AM
Posts: 293 salem, oregon. usa
elmor
salem, oregon. usa
A lot of guys, myself included, are NOT buying motorhome 413's. We are trying to build early 60's engines from New Yorkers and such, and we're not dealing with funky heads and water pump housings and all that crap. Your first mistake was buying a MOTORHOME 413, and expecting to be like a 440. I agree that a 440, or 400 are probably better starting points for building high horsepower, but sometimes you've gotta use what you've got. I think it's cool to use something that not everyone else has, and if you look at factory specs, you'll see that early 413's had as much, and in some cases, more torque than a stock 440. These engines will run hard with very little tweaking. I got my 413 for nothing! I don't know of anyone that's giving away 440's.
Re: 413 rant...
[Re: elmor]
#117998
09/11/08 04:53 AM
09/11/08 04:53 AM
Posts: 30,466 Florida STAYcation
dOc !
The village idiot's idiot
Florida STAYcation
But I looooove my 413 .... And YES .. the ticket IS flat-top or domed pistons. The motorhome I have will have those ... plus a ton of flow-work on those "funky" heads. And a roller-cam AND a better fuel-delivery-system. You have a gasser tow-rig ? ....you WANT one of these mills !!
Re: 413 rant...
[Re: dOc !]
#117999
09/11/08 05:46 AM
09/11/08 05:46 AM
Posts: 12,291 Kent, Wa
340SHORTY
Truck Nut
Truck Nut
Kent, Wa
I had a 72 class A Winnebago that has the Ind 413. That tank weighed 14,500 pounds with my stuff in it. A few years ago I went on a out of town job and hauled my old 5,000 + pound 73 F250 4x4 on my 1,500 pound trailer behind it. I got over 13 miles to a gallon of fuel. I liked my 413.
I am truckless..
Re: 413 rant...
[Re: Greg55_99]
#118000
09/11/08 07:32 AM
09/11/08 07:32 AM
Posts: 420 Central Ohio
Ledman_70
Central Ohio
I'm running a 65 413 in my 64 Polara that's been bored to 426 cubes. It's running stock flat top pistons, 513" Lunati cam, Edlebrock intake, 906 heads, headers, 750 Holley, and 4-spd. It's not a race car, but stomping it at 20mph puts it sideways through 2nd gear, and the torque is massive! I can take off in 4th gear. The rear has 3:91's, so I know that makes all the difference, but I regularly take off in 2nd in normal driving and it's not even noticeable. I know you can get a lot more from a 440, but 413's are usually a lot cheaper...I know where one is sitting with a 727 on it for $200.
Jeff Adams
64 426 Polara
Re: 413 rant...
[Re: Greg55_99]
#118004
09/12/08 01:02 AM
09/12/08 01:02 AM
DaytonaTurbo
Manitoba, Canada
I agree the motor home 413's did come with a lot of odd ball parts, but most of that stuff you're junking anyway. You can slap on a set of aftermarket heads, a mild cam with new rockers and pushrods, new t-chain, timing cover/water pump housing can be scored at the junkyard or moparts/ebay for cheap enough, or just buy new, etc. Pretty much you can buy everything you will re-use when you rebuild that 440 block you will buy some day. As far as rebuilding the 413's short block, I will say that yeah, that's very questionable and probaly not worth it. But for something to just drop in and beat the tar out of without worrying about it, the 413 is a decent choice.
Re: 413 rant...
[Re: DaytonaTurbo]
#118006
09/12/08 01:18 AM
09/12/08 01:18 AM
Posts: 1,213 Los Angeles, CA
Mobarge
Los Angeles, CA
I wanted a 440 for my Plymouth, but this 413 literally dropped in my lap. Deal was too good to pass up: Freshly machined, magnafluxed, balanced, blueprinted, 440 six pack rods, worked 516 heads, and $800 worth of brand new Arias flat top aluminum pistons. The builder who hooked me up with it builds 413s, 440s and Hemis for the high-dollar '62 to '65 cars built by Bob Mosher. It's actually a very strange block - no casting number on the side, but on the pad it says it's a 1973 truck block, which I assume is different than a motorhome engine.
'71 SSP - SOLD!
Re: 413 rant...
[Re: Mobarge]
#118007
09/12/08 07:46 AM
09/12/08 07:46 AM
Posts: 856 1.5 hours SE of Pittsburg, Pa
geno440
i got 3 of them if any one wants to buy one ...... lol
Love them 68 MOPARS! GTS 340 auto, Charger R/T 440 4-speed, Superbee 383 auto, GTX 440 auto, D100 (new front frame 5.7 hemi - in process), Formula S 340 4-Speed A/C (it's green), 383 auto Roadrunner (maybe a hemi - waiting) and a 68 W200 Power Wagon. Drivers: 07 Cummins and 14 Ecodiesel 4x4.
