2000 5.9L Durango oil level ? #1178862
02/15/12 03:57 PM
02/15/12 03:57 PM
Joplin, Mo
rt66jim Offline OP
rt66jim  Offline OP
Joplin, Mo
I purchased a 2000 5.9L Durango a few months ago. I have alwys thought that all gas trucks had an oil capacity of 5 qts. When you changed the oil and filter. This thing holds 7 by the indicator when changed. I have put in a tube and indicator and double checked the part #s. The correct tube and indicator are in it.
Did they have any 7 quart factory pans? I cann't find a listing in the parts catalogs.
Doesn't look like this pan has ever been changed.
Any thoughts? Jim
Re: 2000 5.9L Durango oil level ? [Re: rt66jim] #1178863
02/15/12 04:08 PM
02/15/12 04:08 PM
Missouri U.S.A.
71yelladustr Offline
Missouri U.S.A.
No 7 qt pans. Should hold 5.5 qts at the most. Which filter are you using? You might get close to 7 with a long ford style filter.
392 gen III hemi on E-85 727 trans Dana 60
10.02@134
Re: 2000 5.9L Durango oil level ? [Re: 71yelladustr] #1178864
02/15/12 05:22 PM
02/15/12 05:22 PM
Joplin, Mo
rt66jim Offline OP
rt66jim  Offline OP
Joplin, Mo
Filter is the short 5281090ba mopar. 5qts just barely toches end of dipstick.
Re: 2000 5.9L Durango oil level ? [Re: rt66jim] #1178865
02/15/12 10:25 PM
02/15/12 10:25 PM
Marysville, O-H-I-O
70Cuda383 Offline
70Cuda383  Offline
Marysville, O-H-I-O
is it the right dipstick? the magnum dipsticks are rather long.
I can go measure one if you want me to. so you can compare it to what you have.
**Photobucket sucks**
Re: 2000 5.9L Durango oil level ? [Re: 70Cuda383] #1178866
02/15/12 10:29 PM
02/15/12 10:29 PM
Joplin, Mo
rt66jim Offline OP
rt66jim  Offline OP
Joplin, Mo
The part # on the dipstick is correct part# by the partrs catalog application. It also has the correct tube that goes with the dipstick. I replaced both together at the same time.
