A body front track width different drum vs disc? #1178758
02/15/12 09:39 AM
02/15/12 09:39 AM
Frederiction. New Brunswick ,C...
RTshaker Offline OP
RTshaker  Offline OP
1970-72 A body front track width different drum car vs disc ?.I have 10" drums looking to switch to disc all OEM parts .I don`t have much clearence to fender on a 14x7 alumn rim 235x60-14 if it is slightly wider with the disc st-up ..problems.Thanks
Re: A body front track width different drum vs disc? [Re: RTshaker] #1178759
02/15/12 12:07 PM
02/15/12 12:07 PM
RTshaker Offline OP
RTshaker  Offline OP
Urgent anyone??? looking at making a trade ASAP
Re: A body front track width different drum vs disc? [Re: RTshaker] #1178760
02/15/12 01:03 PM
02/15/12 01:03 PM
A Banana Republic near you.
JohnRR Offline
JohnRR  Offline
If you are switching to a KH small bolt pattern brake setup there shouldn't be a track width difference. There is one if you are switching to the big bolt pattern 73 up setup.
Re: A body front track width different drum vs disc? [Re: JohnRR] #1178761
02/15/12 01:19 PM
02/15/12 01:19 PM
RTshaker Offline OP
RTshaker  Offline OP
Great thaks very much could have been a deal braker . John how much does the 73 up increase thye width ?
Re: A body front track width different drum vs disc? [Re: RTshaker] #1178762
02/15/12 01:57 PM
02/15/12 01:57 PM
JohnRR Offline
JohnRR  Offline
About 5/8" per side.
