Switching oil in a '07 Chrysler Aspen #1178634
02/15/12 01:05 AM
02/15/12 01:05 AM
Angleton, Texas
69rrvert Offline OP
69rrvert  Offline OP
Angleton, Texas
I recently acquired a '07 Chrysler Aspen with 72,000 miles and the 5.7 Hemi. This is my first used vehicle since 1997. I have always started them off on Mobil 1 synthetic oil and the Napa Gold oil filter. The sticker on the Aspen states that it has Quaker State 5w-20 in it. I am not sure what filter yet. I want to change the oil to Mobil 1 with the Napa Gold filter. Are there any issues that may come up if I do this? Thanks, Steven
Re: Switching oil in a '07 Chrysler Aspen [Re: 69rrvert] #1178635
02/15/12 01:16 AM
02/15/12 01:16 AM
Canada
WO23Coronet Offline
WO23Coronet  Offline
Canada
I wouldn't think so, I have an 05 Magnum RT (same engine) and I always put 5-20 synthetic in it, but whatever is on sale, sometimes Mobil 1, somtimes Castrol, other times Quaker State. I used to use FRAM filters, but got the scared out of me by a post on here about how bad they are. Like you I switched to Napa Gold recently. I've never had any issues with using different brands of oil
Re: Switching oil in a '07 Chrysler Aspen [Re: WO23Coronet] #1178636
02/15/12 01:39 AM
02/15/12 01:39 AM
Morristown Tn.
71birdJ68 Offline
71birdJ68  Offline
Morristown Tn.
Go to wal mart and buy the 5qt jug it's cheaper. Always use what weight the book calls for the way the motors are today you can mess one up if you stray too far from what it says. I use a mobil one filter too.I know it costs more but i go 10,000 between changes which is cheaper in the long run, and i have 418,000 on my neon.
Re: Switching oil in a '07 Chrysler Aspen [Re: 71birdJ68] #1178637
02/15/12 01:54 AM
02/15/12 01:54 AM
Angleton, Texas
69rrvert Offline OP
69rrvert  Offline OP
Angleton, Texas
Thanks for the info. My concern is switching from the regular oil to the synthetic at this mileage. Thanks, Steven
Re: Switching oil in a '07 Chrysler Aspen [Re: 69rrvert] #1178638
02/15/12 02:20 AM
02/15/12 02:20 AM
Gainesville,FL
goldmember Offline
goldmember  Offline
Gainesville,FL
They made an Aspen in 07? [Edited by Moparts - Family Friendly Site - Keep it clean] have I been? I'd put whatever you like in the weight the manufacturer states and be done with it.
Re: Switching oil in a '07 Chrysler Aspen [Re: goldmember] #1178639
02/15/12 02:57 AM
02/15/12 02:57 AM
Texas
Daty Rogers Offline
World's Greatest Husband. I love you Robyn
Daty Rogers  Offline
Texas
No, just use the same weight. Where was the sticker, facory or oil change place?
-Daty
Re: Switching oil in a '07 Chrysler Aspen [Re: Daty Rogers] #1178640
02/15/12 03:04 AM
02/15/12 03:04 AM
Eugene, Oregon
Secret Chimp Offline
Eugene, Oregon
You can use a 0W-30 or 5W-30 without any problems. Most cars nowadays are using 20 weight oils for getting that last fraction of a MPG out of the EPA tests.
1967 Dodge Coronet Deluxe station wagon
1.03" T-bars, QA1 arms/rods, Cordoba/GM Metric/Volare brake & knuckle, XHDs, Hellwig rear sway, 318 Magnum w/ air gap, 727, 3.23s
Re: Switching oil in a '07 Chrysler Aspen [Re: Secret Chimp] #1178641
02/15/12 10:33 AM
02/15/12 10:33 AM
NC
DCM71cuda Offline
DCM71cuda  Offline
NC
An '07 will have an MDS engine...so (from what I've been told) you need to use to correct oil (5w-20)or the MDS system will not work properly. If I'm wrong on this, somebody please correct me.
My 2006 truck (currently 205,000 mi) has a 5.7....I initially ran dino oil changing at about 4k miles. I switched to synthetic at about 80k. I run the extra long Baldwin filter (the filter alone holds almost a quart), and usually get Quaker State full synthetic, though I'll buy whatever name brand if I find a good price.
Usually go about 5k between changes. It is just getting to the point that I have to add a small amount of oil between changes.
Re: Switching oil in a '07 Chrysler Aspen [Re: 69rrvert] #1178642
02/15/12 10:38 AM
02/15/12 10:38 AM
S.E. Michigan
ZIPPY Offline
ZIPPY  Offline
S.E. Michigan
No worries whatsoever, don't give it a second thought.
Put in your favorite brand of synthetic 5w20.
If you're mostly concerned about leaks, consider:
5.7s really don't have any "gaskets" per se'.
99% o-rings. The closest thing to a gasket it has is the oil pan, and it is molded rubber/a permanant part of the windage tray. As long as it doesn't leak with conventional oil, it won't with synthetic either.
Rich H.
Esse Quam Videri
Re: Switching oil in a '07 Chrysler Aspen [Re: 69rrvert] #1178643
02/15/12 02:47 PM
02/15/12 02:47 PM
Vancouver, WA
MoparMarq Offline
MoparMarq  Offline
Vancouver, WA
Changed one car (Toyota) to all synthetic at 150K mi., another (Acura) at 80K, another ('01 Durango) at 50K. No leaks or problems with any of 'em.
Re: Switching oil in a '07 Chrysler Aspen [Re: MoparMarq] #1178644
02/15/12 11:19 PM
02/15/12 11:19 PM
Canada
WO23Coronet Offline
WO23Coronet  Offline
Canada
Since we're on the topic of "does changing a hile mile vehicle to synthetic hurt it?", does it hurt anything? I've heard guys swear up and down that it'll cause a high miler to spring leaks like old faithful at Yellow Stone Nationial Park. I think it's BS, but is there something to it? or just myth?
Re: Switching oil in a '07 Chrysler Aspen [Re: WO23Coronet] #1178645
02/15/12 11:34 PM
02/15/12 11:34 PM
Ramona, CA
NicksGarage Offline
NicksGarage  Offline
Ramona, CA
Myth.
Anyone remember Arco Graphite oil? We had a '71 Pontiac Grand Safari wagon with a 455 when I was a kid and my dad switched to Arco Graphite and that stuff seeped out of every place it could find including the head gaskets from what I remember.
Re: Switching oil in a '07 Chrysler Aspen [Re: ZIPPY] #1178646
02/16/12 02:16 AM
02/16/12 02:16 AM
Pacific NW USA
CompSyn Offline
CompSyn  Offline
Pacific NW USA
Or better yet, 0W-20 Full Synthetic. Does everything the 5W-20 Synthetic does only better, and it's the same price. Don't be hesitant on the 0W. It's not a downgrade; it's the contrary.
And for the money, the Napa Platinum oil filter is now the best widely available oil filter on the market with it's 100% micro-glass media. Yes! Although, the 1950s tech paper oil filter will suffice, why do that to your engine when the modern tech micro-glass is now so easily attainable.
Look Inside PlatinumNAPAFilter™ - Video Link
Re: Switching oil in a '07 Chrysler Aspen [Re: CompSyn] #1178647
02/19/12 10:10 PM
02/19/12 10:10 PM
Angleton, Texas
69rrvert Offline OP
69rrvert  Offline OP
Angleton, Texas
Thanks for all the info. Looks like the next oil change will be to Mobil 1 synthetic. Thanks, Steven
