Cam grinder preferences?
#1178131
02/14/12 06:55 AM
02/14/12 06:55 AM
Posts: 4 ND
408_dup7
ND
Just looking for some opinions on cam manufacture? Getting ready to put my 408 together and all I need is a stick. Not sure what grind I should get either, Its going in an 86 W150 (5,600lbs) that will soon have OD w/ 2k rpm stall, 4.10 gears on 33's. Motor; holley 670 SA, RPM performer, 1.625" (pri) 2.5" (coll) headers, 2.5" Full length true dual exh w/ 30" glass packs (no X or H)... KB hyper 9.3:1 dished pistons, RHS X heads 2.02/1.60, Comp bee hives w/ 1.5 rockers, last but not least 7 keyway cam gear. I've heard good things about Engle, Isky, brown, lunati, and comp. Not sure if they all grind on a 904 profile though, probably not necessary for my application but still good to know. I'm guessing somewhere between 220-230 ish dur and 430-475 ish lift is where I'll want to be, but not sure. Also do I want a split or single pattern? This will be a DD pavement pounder / weekend wheeler / tower (2k lbs ave - 6k lbs max). Will se alot of winter driving too. I'd like a noticeable idle but nothing too extreme.
Re: Cam grinder preferences?
[Re: 408_dup7]
#1178133
02/14/12 11:54 AM
02/14/12 11:54 AM
Posts: 3,544 Syracuse,NY
CompWedgeEngines
Syracuse,NY
There are plenty of companies that CAN grind a good cam. That is not the problem. You want someone who KNOWS how to spec the right cam. There are plenty of us on here who spec and order custom cams all the time. There are plenty of variables that come into play, and getting the " right" cam is ( in my opinion) more than simply oepning a cam catalog and using the footnotes. With all that being said, why would you not use the guy that you purchased your heads from? He has the best chance of knowing your combination, since he already has all that info. I know Brian specs custom cams, and even though I COULD sell you one, as well as others here, I'd suggest using the guy already in your corner. I know if I was building an engine, and I found out the customer was asking for a cam suggestion on the internet, I wouldnt be thrilled. ( I realize IMM isnt building the engine, but you trusted him enough to do the heads right?)Stick with your guy, and let him use his experience to make the right choice for you. Sounds like a cool project...I miss my old trucks.
RIP Monte Smith
[Re: CompWedgeEngines]
#1178134
02/14/12 12:00 PM
02/14/12 12:00 PM
dartman366
Mt. Vernon, Ohio
There are plenty of companies that CAN grind a good cam. That is not the problem. You want someone who KNOWS how to sepc the right cam. There are plenty of us on here who spec and order custom cams all the time. There are plenty of variables that come into play, and getting the " right" cam is ( in my opinion) more than simply oepning a cam catalog and using the footnotes. With all that being said, why would you not use the guy that you purchased your heads from? He has the best chance of knowing your combination, since he already has all that info. I know Biran specs custom cams, and even though I COULD sell you one, as well as others here, I'd suggest using the guy already in your corner.
100%, I had RyanJ do my heads for my 408 and he profiled the cam for me, I have not been able to improve on his decision.
[Re: dartman366]
#1178135
02/14/12 12:53 PM
02/14/12 12:53 PM
Posts: 16,123 Grand Haven, MI
patrick
Grand Haven, MI
if I were looking at a shelf grind, I'd go lunati voodoo 60402 or 60403 for that combo.
intake to exhaust flow ratio is pretty good with magnum heads, and your exhaust will be relatively unrestrivtive that I don't think you'll NEED a split pattern cam.
custom grinding, I'd go with bullet cams, and this lobe HC272/336 for both intake and exhaust
specs: 272 dur at .006" 224 @ .050 140 @ .2" .3360" lobe lift, .504" with 1.5 rockers
I'd have it ground on a 112LSA and install it on a 108 ICL.
[Re: Brian Hafliger]
#1178141
02/15/12 09:59 AM
02/15/12 09:59 AM
patrick
Grand Haven, MI
That bullet lobe would work great, but I'd put it on a 108lca straight up! Brian
thanks for making me feel smart my thoughts were on the wider LSA was that I like a nice idle, and I'd take the slight hit in mid range torque to not have the motor nose over quite so much above the torque peak....I swag'ed the wider LSA would pull good up to about 5500 RPM, if need be...
man, the cam Dave recommended is HUGE for your app, IMHO...personally I think A LOT of guys way overcam their engines....
[Re: 408_dup7]
#1178142
02/15/12 10:17 AM
02/15/12 10:17 AM
Posts: 1,409 Ont. Canada
10.90 Racer
super street
super street
Ont. Canada
I figured everyone has a preference so I thought I'd ask. I wasnt trying to undermine Brian, he knows his stuff and does great work! I already asked him and he suggested a Comp 218/223 462/473 (idr the lsa). I'll be honest, I'm a lil hesitant to take a race engine builders word for a 4x4 since Dave at hughes suggested a 237/242 548/555 108lsa. This is after we discussed my application from bumper to bumper for 45min. I'm a novice (first motor) so I took his advice, later found out how wrong it was. This was a year ago so I have since edumacated myself some in terms of cam applications. I still dont really have a clue lol, but If someone suggests the above, I now have enough sense to say "yeah right". I'll trust Brian since I've yet to hear bad about him, unlike what Ive read/experianced with Hughes. That and hes extremely nice were as Dave treats you like an incompetent monkey. Brian, If I offended you I apologise. I forgot that your a member here :/. I'll call you first thing tomorrow to order . Dustin
Once you have been around a while you will know the guys that know there stuff...... they always spec cams on the smaller side compared to the masses.............
If someone phones 10 different cam manufactures out of the blue..... they will get 10 different cam grinds......... most won't run any better then the next guys.... But most people will buy the biggest cam spec'd to them, because we all know bigger is better........ That said and with all cam companies knowing this,,,, If you want to sell cams, you better spec them big........
I have many times put smaller cams in engines and they picked up power........
