Re: Engine falling off just past 4k - carb limit?
[Re: RapidRobert]
#1177553
02/21/12 01:06 AM
02/21/12 01:06 AM
Posts: 817 Eugene, Oregon
Secret Chimp
Eugene, Oregon
Couple of things:
I tried running it up until it seemed to nose off, backed off, then floored it again. Every time I did this it got up to around 4400-4500 rpm and started making an angry ping pong ball noise that sounded like detonation and power fell off with a "stop flooring it" type of feeling. I don't know if I ought to not be running 87 now or if it's getting so lean up top that it's pinging (maybe holding a higher RPM at lean-ish mixture heats the cylinders to the point of detonation will happen at higher RPMs but not when running it up in one go? I dunno, maybe something was rattling), but that's what happened.
I also tested my fuel pressure and I'm getting a good 6.5-7 psi at idle. I couldn't get my dang metal tees to seal well enough at driving RPMs in my garage to be comfortable actually driving with the gauge hanging out from my hood, but the pump seems strong.
My guess at this point is that the carb is just too low-capacity and too lean for the amount of air I'm trying to pull through it at this point. I'm all set to put my 650 Carter AVS on save for an air cleaner and a pressure regulator (didn't expect to have such a He-Man old pump but I sure need one now) so I'm just going to go ahead and do the swap and see what happens when it can get more fuel down.
1967 Dodge Coronet Deluxe station wagon
1.03" T-bars, QA1 arms/rods, Cordoba/GM Metric/Volare brake & knuckle, XHDs, Hellwig rear sway, 318 Magnum w/ air gap, 727, 3.23s
[Re: Secret Chimp]
#1177554
02/21/12 02:51 AM
02/21/12 02:51 AM
Secret Chimp
Eugene, Oregon
Before I go throwing on the parts I have on hand and getting disappointed, should I run a fuel pressure regulator with the carb I'm using? I can't find any definitive specs for AVSes, only AFBs.
[Re: Secret Chimp]
#1177555
02/21/12 12:14 PM
02/21/12 12:14 PM
RapidRobert
OE avs/afb's have the same type float leverage system so the psi limits would be the same. Can I persuade you to check psi at the carb inlet at the rpm/pedal depression (load)AT SPEED that it acts up at. Need ~several psi. I still think you have a fuel delivery prob . I'd set a can of gas in the eng compartment plumbed to the mech pump inlet & retry it & that takes the hard lines to the rear of the pump and the 2 neoprene connector hoses and the sender hard line pinholes and partly plugged sock all of it out of the equation. The mech pump may be weak & cannot handle the full throttle fuel demands of 4K+ but will handle 5K no load. less likely would be if there's a partly plugged screen filter in the carb inlet. Check float drop spec also. To ans your Q My "airtex" parts house pump puts out over 7 psi & I'm getting a reg (mileage is poor). eddy 1406
[Re: Secret Chimp]
#1177556
02/21/12 12:26 PM
02/21/12 12:26 PM
Posts: 24,562 Brookeville, Md
Mr.Yuck
Brookeville, Md
Couple of things:
did you swap the cam out when you changed the t-chain? are you sure you didn't bend a few push rods when the old chain was stretched out? Have you tried higher octane gas? I ran a bone stock 318 2bbl 69 coronet to 15.69 1/4's shifting at 5200 w/ the stock 2bbl on 93. Have you checked the plugs? Maybe go run it hard and get it back to the garage and take a look at a few of them.
[Re: Mr.Yuck]
#1177557
03/01/12 05:16 PM
03/01/12 05:16 PM
Secret Chimp
Eugene, Oregon
It was the carb. I just took my car out for its first run with the AVS on - HOLY F^*# this thing GOES now! Runs like the stink with the secondaries open and has more poke in normal driving too. But holy crap this car is fast now. I'm still grinning.
[Re: Secret Chimp]
#1177558
03/01/12 05:24 PM
03/01/12 05:24 PM
Posts: 75,015 U.S.S.A.
JohnRR
U.S.S.A.
What carb did you originally have on it that was causing this problem ?
[Re: JohnRR]
#1177559
03/01/12 05:46 PM
03/01/12 05:46 PM
Secret Chimp
Eugene, Oregon
The original Carter BBD 2 barrel.
[Re: RapidRobert]
#1177561
03/01/12 05:58 PM
03/01/12 05:58 PM
Secret Chimp
Eugene, Oregon
LOL yes. Now I just need to get rid of these 2.93 gears for some 3.55s and I'll really be grinning...
[Re: Secret Chimp]
#1177562
03/01/12 06:03 PM
03/01/12 06:03 PM
Mr.Yuck
Brookeville, Md
ohh I thought you had a small 4bbl on it.. go get some gears son
[Re: Mr.Yuck]
#1177563
03/01/12 06:11 PM
03/01/12 06:11 PM
Secret Chimp
Eugene, Oregon
This is my first run in it (empty road by the local ce-ment plant, no animals harmed during filming) http://www.youtube.com/watch?v=xJMXl09IAEs&feature=youtu.beI'm sure that looks glacial to you guys but my fastest car previously was my 1.8 liter 140 horsepower Miata :P
