833 Teardown/inspection tips #1176666
02/11/12 08:58 PM
02/11/12 08:58 PM
USA
SSAAHemiFan Offline OP
USA
Getting ready to rebuild my first 4 speed - It was a swap meet grab so I wasn't able to drive it.
I pulled the cover and did a visual inspection before purchase, it look's like it has never been apart and the fluid was free of debris.
Any disasembly tips or things I should check while I am tearing it down that will make deciding what parts need to be replaced easier ?
I found a couple of articles in the magazines but nothing on what to inspect while you are taking it apart. They just replaced everything.
Re: 833 Teardown/inspection tips [Re: SSAAHemiFan] #1176667
02/12/12 01:18 AM
02/12/12 01:18 AM
closer to Canadian beer!
torkrules Offline
I'm neurotic
torkrules  Offline
I'm neurotic
Dog teeth on the gears. Excessive wear on the counter shaft. Cracks or wear on blocker rings. Forks for bends or wear. Wear or roughness in the bearings. Pitting or unusual wear on gear teeth.
Re: 833 Teardown/inspection tips [Re: SSAAHemiFan] #1176668
02/12/12 12:22 PM
02/12/12 12:22 PM
Iowa State fan
kilroy Offline
kilroy  Offline
Iowa State fan
Depth blocker rings sits on the gears sychro cone is another to check for, and wear on the inside grooves of blocker rings.
1973 Charger, former SE, former auto
I'm not trying to be difficult, it comes naturally....
Re: 833 Teardown/inspection tips [Re: kilroy] #1176669
02/13/12 01:59 AM
02/13/12 01:59 AM
USA
USA
Thank You
Re: 833 Teardown/inspection tips [Re: SSAAHemiFan] #1176670
02/13/12 03:07 PM
02/13/12 03:07 PM
n.e. pa.
65rbdodge Offline
65rbdodge  Offline
n.e. pa.
buy yourself a REALLY good set of snap ring plyers. i was able to do everything except replace the bushing where the slip yoke slides in, took it to a trans. shop, the guy did it for free.
Re: 833 Teardown/inspection tips [Re: 65rbdodge] #1176671
02/14/12 11:33 AM
02/14/12 11:33 AM
New Jersey
Craig Offline
Craig  Offline
New Jersey
DEFINITELY get good snap ring pliers, I tried to do without and it was miserable!
67 Dart, 426 Hemi, 9.23/145mph, 3400lbs, footbraked, owned since 1982
