W9 water plumbing #1176306
02/11/12 12:36 AM
02/11/12 12:36 AM
United States
W
W9 Dart Offline OP
W9 Dart  Offline OP
W
United States
Lets see your W9 headed water plumbing and water block. I'm trying to get some ideas of clean set ups
Re: W9 water plumbing [Re: W9 Dart] #1176307
02/11/12 02:14 AM
02/11/12 02:14 AM
Ambridge, Pa.
rickraw Offline
rickraw  Offline
Ambridge, Pa.
here's mine.
Re: W9 water plumbing [Re: rickraw] #1176308
02/11/12 08:34 AM
02/11/12 08:34 AM
United States
W
W9 Dart Offline OP
W9 Dart  Offline OP
W
United States
Where did u get that block rick? Do u have anymore pics of it and how it is mounted to the valley tray. I'm assuming u just ran the two rear lines straight from the back corners to the block?
Re: W9 water plumbing [Re: W9 Dart] #1176309
02/11/12 09:38 AM
02/11/12 09:38 AM
Ambridge, Pa.
rickraw Offline
rickraw  Offline
Ambridge, Pa.
a friend of mine tig welded the box. angle welded on bottom & mounted to motor plate. helicoiled bolt holes & cut recess for tstat. swivel tstat housing.
Re: W9 water plumbing [Re: W9 Dart] #1176310
02/11/12 09:40 AM
02/11/12 09:40 AM
Ambridge, Pa.
rickraw Offline
rickraw  Offline
Ambridge, Pa.
another
Re: W9 water plumbing [Re: W9 Dart] #1176311
02/11/12 09:41 AM
02/11/12 09:41 AM
Ambridge, Pa.
rickraw Offline
rickraw  Offline
Ambridge, Pa.
another.
Re: W9 water plumbing [Re: rickraw] #1176312
02/11/12 10:40 AM
02/11/12 10:40 AM
PA
W5DART66 Offline
W5DART66  Offline
PA
This is best set up I have used.
Re: W9 water plumbing [Re: W5DART66] #1176313
02/11/12 10:41 AM
02/11/12 10:41 AM
PA
W5DART66 Offline
W5DART66  Offline
PA
2
Re: W9 water plumbing [Re: W5DART66] #1176314
02/11/12 10:42 AM
02/11/12 10:42 AM
PA
W5DART66 Offline
W5DART66  Offline
PA
3
Re: W9 water plumbing [Re: W9 Dart] #1176315
02/11/12 11:06 AM
02/11/12 11:06 AM
MR_P_BODY Offline
MR_P_BODY  Offline
This is what I made up
Re: W9 water plumbing [Re: MR_P_BODY] #1176316
02/11/12 11:09 AM
02/11/12 11:09 AM
MR_P_BODY Offline
MR_P_BODY  Offline
A manifold running down each side to the front can
where both sides merge and has the radiator cap...
thats the highest point in my cooling system
Re: W9 water plumbing [Re: W5DART66] #1176317
02/11/12 11:13 AM
02/11/12 11:13 AM
United States
W
W9 Dart Offline OP
W9 Dart  Offline OP
W
United States
My buddy Tory (Tshell) gave me this same design to use too.. what size pipe is that?
Re: W9 water plumbing [Re: rickraw] #1176318
02/11/12 02:57 PM
02/11/12 02:57 PM
France Europe
Laurent Offline
Laurent  Offline
France Europe
Hello
Nice water box !
What is aluminum thickness ?
Re: W9 water plumbing [Re: Laurent] #1176319
02/11/12 03:50 PM
02/11/12 03:50 PM
Ambridge, Pa.
rickraw Offline
rickraw  Offline
Ambridge, Pa.
thanks. used 3/8 plate.
