My factory service manual lists a clearance for the 273's bushed rockers, but literally just has a blank line in the column for the 318. I know these things are supposed to run loose on the shaft and none of the holes appear to be ovaled out, but is there any way to tell if they've worn beyond factory looseness? Inner diameter limit maybe? I've searched but I can't find anything.
1967 Dodge Coronet Deluxe station wagon
1.03" T-bars, QA1 arms/rods, Cordoba/GM Metric/Volare brake & knuckle, XHDs, Hellwig rear sway, 318 Magnum w/ air gap, 727, 3.23s
